BMW 3-Series (E90 E92) Forum
DIY Valve cover removal N55 E92
11-20-2015, 09:15 PM | #1 |
Rep 245
I recently had the "opportunity" to remove my valve cover and didn't find any tutorials so I thought I'd post one. It's quite different from the N54 though likely similar to the N20 and N26. At any rate, it's not your grandfather's valve cover.
My PCV valve had failed at 80K Miles causing both the front and rear main crankshaft seals to howl like hyenas. More info here: http://www.e90post.com/forums/showthread.php?t=1139795 While I was at it, I took a look at the carbon buildup. It's insanely difficult to unplug the ECU wires but I got enough of them loose to pull the intake manifold off a little and take a peek. Didn't seem too bad to me for 80K so I just poked at them with a popsicle stick to get the chunks off and buttoned it back up. Pic below. I wrote this for the 2-door 3's E92/E93 but other models are similar. The 4-door models like E90, E91, and F30 are slightly easier because the engine doesn't go as far under the windshield, and the smaller cars E87, F20, etc. are a little harder of course but the differences are mostly with respect to the windshield wipers and cowl. Special tools needed:
Supplies needed:
Torque specs:
Procedure:
09-21-2016, 02:22 PM | #3 |
Rep 245
I replaced the front seal and immediately the rear seal began making noise -- which led me to look at the valve cover.
I never did replace the rear seal, it's completely dry and silent to this day. I assume the front seal didn't need replacement either. |
11-04-2016, 07:34 PM | #4 |
Rep 226
Thank you very much for posting this. I replaced my VC gasket and spark plug insert gaskets a couple of weeks ago and this was very helpful. I ended up not replacing the VC itself as I was fixing an oil leak and didn't want to spend the additional $400 for preventative maintenance.
I do have some extra comments to add based on my experience:
Pics of the plastic piece I broke off as well as a pic with all off, including the spark plug inserts (and injectors). Last edited by cahme; 11-04-2016 at 08:02 PM.. |
11-04-2016, 08:05 PM | #5 |
Rep 245
Thanks for the feedback cahme! I hadn't noticed the bolt-count error but in looking at my pics above I see that my car also has 26 bolts. It's pretty strange the way they designed it to take 28 bolts, thought they could get away with 24, then settled on 26.
Good to know it can be done without the windshield wiper shenanigans, at least on a E90. Maybe the E92/E93 are the only models that require the cowl lift, or maybe I lifted it unnecessarily? But I found the same thing that you did -- it's really wedged in there between the fuel rail and the cowl -- and that's the reason I stressed in this writeup to just suck it up and get those things out of the way. Were you able to get the fuel rail off without breaking those clips? I didn't have the right size crows-foot and hadn't yet decided to remove the intake manifold so I googled a pic of them to see how they latch and tried every possible combination of wiggling, sliding and pulling, only to end up breaking both of them. I wish I could afford to replace them, but luckily they still work fine. That's one of the reasons I suggest cleaning your valves first so that you can easily get the fuel rail off. Where was your oil leak? I thought that was a N54 problem. Did you try just tightening the bolts first to attempt to fix it? |
11-04-2016, 11:10 PM | #6 |
Rep 226
Yes, I was able to remove the clips on the fuel rail without breaking them. I remember there was a tab on the back of the inside of the clip. I can't exactly picture it, but I do still have my beauty covers off, so I should be able to get a pic tomorrow.
For my oil leak, it was coming from under the spark plug inserts (buckets). I removed the lid which exposed the injectors and could see the oil grime under. I had to remove the injectors (1 black bolt + special puller tool) and the buckets (4 bolts) and then it was clear where the leak was. If you look at my pic of engine with VC off, you will see a plug in the head between each spark plug pair. If you look at the center plug (between spark plugs 3 & 4), you will see it's black while the plugs between spark plugs 1 & 2 and 5 & 6 are silver. Well, the black is because that plugged hole is full of oil. I've added a few more pics showing the dis-assembly of the spark plug insert buckets. The first should be familiar as it's what's exposed even with the VC on. The next two are with the "lid" of the bucket removed where you can see the mess. My VC gasket was actually fine; probably because it was changed with the VANOS recall not too long ago. Also, as you can see, I ran with the idea of balloons to keep injectors & fuel lines clean |
11-05-2016, 01:10 AM | #7 |
Rep 245
Interesting, your 2011 E90 has all these "buckets" and "lids" but my 05/2011 E92 has nothing but a flimsy scrap metal Tee holding the injectors in. It looks to me like the head is completely different in the plug/injector regions.
P.S. that plastic part that broke from your valve cover is the 2nd of 2 drains from the PCV oil separation system. The first is just a tiny hole but the 2nd for some reason has a spring loaded one-way valve inside that rectangular tube. |
11-05-2016, 07:49 AM | #8 |
Rep 100
Could a cracked pcv hose cause the whistle? I noticed this crack when I installed my jb4 3 days ago. Now when I have the jb4 turned on I get a whistle, but not when it's turned off?
11-05-2016, 08:28 AM | #9 |
Rep 226
For the record, mine is an E90 with a 5/10 build, so I have one of the early ones.
It looks like you do have the "buckets", but the top injector bracket is different. Here is what realoem shows for the VC for the two: E92 - 5/11 E90 - 5/10 So, my translation is #8 is the bucket and #12 is the lid which are the same for both cars. The injector bracketry are a bit different and realoem is missing some info: E92 - 5/11 E90 - 5/10 The E90 has the top pieces (18-20) greyed out with no corresponding part numbers and the E92 has the lower pieces (11 & 12) greyed out with no part numbers. |
11-05-2016, 11:26 AM | #10 |
Rep 245
Dylan, that hose carries mild vacuum when boost is high and certainly could whistle. The JB4 increases boost and therefore increases that vacuum but I'm very surprised that the correlation is strong enough to notice.
That hose always looks cracked due to the paint so be sure to verify that it's not just an illusion. It shouldn't crack on it's own so I suspect someone was messing with your intercooler or valve cover. Your hose, like most, should have a small electrical connector indicating that it is the version "with heater" and the P/N is listed in the top post. Just break the clips off your old hose to remove. Meanwhile it's not a big deal for it to leak, it won't significantly affect crankcase pressure and although it will draw in a tiny amount of unmetered air, there are 2 more MAP sensors downstream that will figure things out. |
11-05-2016, 12:15 PM | #11 | |
Rep 100
Ill check for a part number and replace it in hopes that it's making the noise. Thanks |
11-05-2016, 12:50 PM | #12 |
Rep 1,073
Dylan, I experienced the same issue. With JB4 installed I would experience the issues with squealing. I was FBO I slowly removed each piece individually until the only thing left was the JB4. I removed the JB4 and the noise is gone. Sometimes during slow speeds I think I can hear it but once I roll my Window down the noise is gone. Fastward to today, Im installing a new valve cover. Im sure it will take care of the issue. Thanks again to vespa for solving the mystery.
11-05-2016, 01:24 PM | #13 | |
Rep 100
Also I found the part number for my piece, but im not sure how to read it. Its Bmw 7584 128 70356728. I'm just confused and am not sure how to look it up. Thanks. |
11-05-2016, 02:01 PM | #14 |
Rep 245
The PCV hose P/N is 11127584128
RealOEM is a great site for finding part numbers. BMW Part Number Price Comparison is a great program for finding the best price. |
11-05-2016, 02:31 PM | #15 | |
Rep 100
11-05-2016, 02:40 PM | #16 |
Rep 1,073
Yes, I am doing myself. It's actually really simple. I've taken my JB4 Stage 2 on and off several times so getting to the valve cover is cake. Struggled a bit disconnecting the injector connector.
11-08-2016, 09:04 AM | #17 | |
Rep 100
Thanks. |
11-08-2016, 09:11 AM | #18 | |
Rep 1,073
I haven't installed my JB4 back on. I wanted to put my new plugs in, but with the cylinder head being cold it wasn’t breaking loose as easily as I wanted to. I’ll chime back in this weekend.
2008 MB 335i-SOLD
2011 AW 335i M Sport- SOLD 2011 BSP 335i-SOLD 2011 BSP 335is- FOR SALE 2018 YMB M3- Current |
11-08-2016, 10:17 AM | #19 | |
Rep 100
11-13-2016, 09:41 PM | #20 | |
Rep 14
Hi I recently did a valve gasket replacement on my n55 also and I put the piece back onto the valve cover gasket and the clip broke on the plastic part would you be able to let me know the part number for the plastic piece thank you
11-13-2016, 10:40 PM | #21 |
Rep 14
I put the plastic piece back underneath the valve cover gently and one of the clips broke off ....
what I would like to know is if this piece has a part number and if so what is the part number or is this piece really necessary and I could put the valve cover back on with out this plastic piece |
11-15-2016, 11:14 AM | #22 | |
Rep 100
