05-18-2016, 12:30 PM | #1 |
Rep 18
F30 Base stereo upgrade..advice needed!
I am more of a mechanical guy than an electrical.
So, pls bear with me… a little. Driving F30 with base stereo(no amp’, no tweeter) for 3 years now. I didn’t care much about the quality of audio but somehow, I do recently. Maybe I will keep this car for another 2 years thus do not want to invest a lot to upgrade audio. Cheap upgrade is in progress and I just bought 2 used F30 OEM HK mid range speakers for front doors only and 2 F30 OEM HK tweeters. Some are saying that I will feel the noticeable difference with added tweeters and hopefully from new mid ranges. At this point, I am also considering adding a cheap F30 OEM HIFI AMP to get slightly a better result(?). Is this worthwhile? If affirmative, will it be a difficult task DIYing installing harness from the AMP to HU or idrive? any link to this DIY will be appreciated. I think I also need an advice on the source of wire harness for this purpose.. I wouldn’t expect a luck that even base stereo has a preinstalled harness for stereo upgrade. I did a moderate amount of search , so pls don't Thanks in advance. |
05-19-2016, 09:05 AM | #3 |
Rep 263
The stock stereo system has no crossovers at all.
If you do the work adding an amp, don't add the quite crappy HiFi amp, but a better one, maybe even with DSP. |
05-19-2016, 09:32 AM | #4 | |
Rep 778
Adding the tweeters makes such a difference, it's night and day. I did one side first then adjusting the balance from left to right to check whether it was worth the effort. The side with the base mid and no tweeter sounded like it was under water compared to the HK side. For a relatively cheap mod it is more than worth it. |
05-19-2016, 10:37 AM | #5 |
Rep 100
I would check ohm ratings before you change anything. You don't want to fry your head unit. I don't know if there is a difference in ohm rating between base speakers and HK speakers...
05-19-2016, 12:09 PM | #6 |
Rep 18
Thanks for all the inputs.
I think I am just adding tweeters and replace mid ranges. Will check more about Ohm rating but I do not think it will be a problem... Maybe more experienced member can chime in for HK mid range + HU_ENTRY. |
05-19-2016, 05:02 PM | #7 |
SEAL TEAM SIX
124
Rep 498
Changing just the speakers and putting tweeters won't do any good to the base set up. You need to de-equalize the signal coming from the HU to make it sound better, which won't be enough.
Been there, done that. Ended up using Techniq's harness + DSP+ amp + comp speakers + subs, then tune. It was actually a lot better than my HK now.
DON'T MAKE ME ANGRY!
GO1 LCI PHEV 30e. M Sport plus Pack, Tech Plus Pack, Comfort Pack, Pano sun Roof, Sensatec dash with Blue stitching, HUD, Galvanic controls. |
05-20-2016, 01:46 AM | #8 |
Rep 263
Yes and besides the weird equalization of Stereo: By just adding tweeters you have to be careful with the sensitivity. I'be tried 2 different tweeters and both were too loud. At the first time the sound seemed improved, but soon my ears were bleeding due to loud high frequencies. Coding HiFi instead of Stereo didn't help too.
By the way I've realized that the stock loudspeakers have bad sensitivity. Unusual as there is anyway quite low power out of the radio. |
05-21-2016, 09:32 AM | #9 | |
Rep 18
I am ordering window frame now.. Hopefully get this all done before the end of June.. Many travel scheduled on June.. |
06-06-2016, 09:03 AM | #10 |
Rep 9
I notice this is an older thread so maybe you have done it already... but..
I ended up getting some Rainbow components and under seat subs. Work with existing wiring, no amps needed and sound quality is greatly improved. Piece of cake to install too. Doors: Rainbow Il-c4 2. BMW F-Series> 2012 Front Subs: Rainbow IL-S8F BMW Woofer Kit Set A couple of frames like you mention. |
06-06-2016, 12:01 PM | #11 |
Rep 263
Did you really have Stereo and not HiFi (US stock) before? Just wondering as Rainbow recommends at least 70W RMS per woofer.
I was also considering the Rainbow set, but finally ended up with Jehnert using it semi-active at a 4x80W amp. Last edited by TePee; 06-06-2016 at 12:21 PM.. |
06-15-2016, 10:06 PM | #12 |
Rep 93
Just picked up a Bimmertech amp for my 2015 328xi directly from Bimmertech. Shipping was lightning fast. The amp was supposed to come with a custom bracket to fit my car to make it literally plug and play. Needless to say there was no custom bracket, just the metal fins like the OEM amp but the Bimmertech amp is larger and did not fit the OEM bracket. I emailed Bimmertech and they asked for pics but I already installed the amp by removing the fins and using very strong double sided tape to secure the amp to the OEM bracket. It was a very tight fit but it worked. The amp is a very significant upgrade with lots of control once you download the software for it from the Bimmertech website. Just make sure you plug the USB cable into the amp prior to installing it and get an extension cause the one Bimmertech sends is only 3 or 4 feet long, which is nowhere near long enough to sit in the drivers seat and make your adjustments. Why even send a USB cable that's this short? Don't these guys try this stuff on their own cars? Anyway, the amp when tuned properly has much more attack and headroom with enhanced dynamic range. The sound system is cleaner, louder and hits harder. Better replacement speakers from Bavsound should make a very substantial difference but the amp by itself is an outstanding upgrade. Kudos to Bimmertech for a very nice amp upgrade but you guys should have the correct bracket for such a popular car without me having to send in pics. Also, what is anyone going to do with a 4 foot USB cable that attaches to the amp in your trunk when you need to sit in the front seat to tune your system? That's goofy, just sayin.
06-16-2016, 10:18 PM | #13 | |
Rep 1,201
I do agree with the uber short USB cable. I have to get a USB hub and another 5 foot cable.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
06-20-2016, 05:28 AM | #15 |
Rep 93
The OEM bracket or "plate", that holds the OEM amp in my 2015 328 is too small for the Bimmertech amp. You cannot fit the amp onto the bracket with the fins attached because there is a piece of metal that sticks up on one side of the OEM bracket that blocks the Bimmertech amp from fitting correctly. I removed the fins and used double sided tape to make it work but it is extremely tight. Bimmertech states on their site that the amp comes with a "custom" bracket, but my amp only came with the fins attached. On my 2016 X3, the OEM bracket holds the Bimmertech amp perfectly with the fins attached and is completely plug and play taking only 10 minutes to swap the amps. I ordered and received both amps at the same time. Neither came with a custom bracket. They are identical with fins attached. The OEM brackets in each vehicle that house the OEM amps are totally different. One amp fit perfectly and was completely plug and play (X3) and the other (328) was not.
