09-25-2016, 06:27 AM | #1 |
Rep 624
Need more rear camber!!
I drive a lot of trackdays and autoX. I run on Michelin Pilot Sport Cup 2.
With the original front camber of 1,3 degrees I got some nasty wear on the front tires outer shoulders. I bought camber plates, set wheels to 3 degrees and this shoulder wear was gone. The front tires now wear down nice and evenly. BUT... I still get this nasty tire shoulder wear at the rear. We've set camber to max what is possible which is just over 2 degrees. I'm pretty sure swapping to Kumho V70 would solve it, they have a totally different carcass but I have the MPSC2 on and can't justify just throwing them out. Anyone else having similar problems with the rear? |
09-25-2016, 08:04 AM | #3 |
Rep 278
That would explain this post on page 48 of the what did you do to your M2 today thread...
M3 Adjuster7909.00 |
09-25-2016, 08:53 AM | #4 |
Rep 2,560
Drives: Rapidly from A to B
Not seeing what you are. I'm at Road America right now. This is drivers rear. 3 track days plus 4500. Will be 4 track days after today.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
09-25-2016, 10:18 AM | #5 |
Rep 624
Those are MPSS or MPSC2? What hot pressure do you run?
09-25-2016, 10:41 AM | #6 |
Rep 2,560
MPSS. Hot at 36 all around. Cold was around 28, 29, 30, 30 for lf, rf, lr, rr.
09-26-2016, 10:23 PM | #7 |
BimmerPost Supporting Vendor
3857
Rep 54,419
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
How much more camber do you need? OEM adjustments should allow more than -2. Reduce body roll will help roll induced camber changes.
09-27-2016, 04:31 AM | #8 | |
Rep 624
The Öhlin Road and Track kit which is on the car has AFAIK stiffer springs than OEM which should already help with body roll. At least a bit. Seems I need some hardware to extend adjustable camber range or swap to other tire model. |
09-27-2016, 11:52 AM | #9 | |
3857
Rep 54,419
Drives: F80 M3
09-27-2016, 12:35 PM | #10 | |
Rep 624
Where can I find adjustable upper links? |
09-27-2016, 02:30 PM | #11 |
3857
Rep 54,419
Drives: F80 M3
09-29-2016, 05:37 AM | #12 | |
Not-So-New Member
103
Rep 61
Current: 2016 BMW ///M2 Black Sapphire Metallic / 6MT
SOLD: 2002 BMW ///M3 Matte Grey Metallic / SMG Core of WrongFitmentCocks |
10-10-2016, 02:18 PM | #14 | |
Rep 624
"Please note that the camber shim kit does not increase the amount of available camber adjustability, but rather rigidly fixes the camber adjustment you make" http://ind-distribution.com/ind/bran...amber-shim-kit |
10-10-2016, 02:22 PM | #15 |
Rep 2,342
What that means is you cannot set the camber to your choosing. So if you needed a specific -2.4 you may or may not not get it. The shims set a specific range of negative camber. If you use the 4mm shim the camber you get is the camber you get, plus the range of the factory.
04-21-2017, 05:40 AM | #16 |
Rep 665
Same problem. Stock suspension, stock setting, the outer wears a lot more and shoulder wear problem too, the inner look hella new...
Upper link adjustable kit anyone? recommendation? |
04-21-2017, 08:24 AM | #17 |
Rep 185
Well, the answer isn't just continually adding more camber, its increasing roll stiffness and caster. Do in this order: Increase positive caster at the front if possible, and run stiffer sway bars and stiffer lowering springs. Its a bit surprising that this car requires so much camber - about the same as a 70's Japanese car. I would have thought the design would be a bit more sophisticated these days like some other brands multi-links with virtual roll centers.
04-21-2017, 11:18 AM | #19 | |
Rep 3,714
