BMW 3-Series (E90 E92) Forum
Super bright and high quality h8 Bulb with 108 leds
11-09-2016, 11:34 AM | #1 |
Rep 1,425
Just wanna share my experience with these H8 bulb with 108 leds.
Its so bright, and well built, its made out of a metal case. It also has a small projector lens I will give it a 10/10 over all Color: 10/10 Super whtie Quality: 10/10 Metal case feels strong and reliable Packaging: 9/10 Fairly simple package, not something fancy, but as long as the bulb has good quality Pic 4 (turned off) vs 5 (turned on) |
11-09-2016, 01:39 PM | #4 |
Rep 707
11-09-2016, 02:21 PM | #5 | |
Rep 1,425
11-09-2016, 03:06 PM | #7 |
Rep 707
11-09-2016, 03:08 PM | #8 |
Rep 1,425
I had them for Fogs. Thought our low beam was Xenon...
I tried it for AE too. Super bright and white just like LUX. But the gutter ring isn't as bright tho. But if you look at these tow pics, the OEM bulb outer ring is kinda losing color too. |
11-09-2016, 04:36 PM | #9 |
Rep 1,117
Drives: 2010 E90 328i 6MT ZSP BSM
Thanks for sharing the pics. The website has an option for resistors for an extra $7. What does that do? Did you run into problems without them?
11-09-2016, 06:44 PM | #10 |
Rep 1,425
Yea I bought the resistor too. If you know how to code your cars, then dont worry about it because you can code off the light bulb error. A resistor prevents error code from coming on using aftermarket light bulbs
11-09-2016, 11:54 PM | #12 |
Where'd my VTEC go?
481
Rep 6,067
That's a shit ton of glare. A fog light should not be lighting up tree branches.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
11-10-2016, 12:19 AM | #13 |
Rep 1,425
11-10-2016, 01:24 AM | #14 |
Where'd my VTEC go?
481
Rep 6,067
That's my point, a fog light is not supposed to. You'll be blinding other drivers. Even a low beam headlight isn't supposed to light up the tree. That's high beam status.
11-10-2016, 01:40 AM | #15 | |
Rep 1,425
If a foglight can blind other drivers, do you know how bright our XENON are? Especially the Lci xenon. PS you have no idea what you are talking about. If thats a high beam status you would have hit a moose by now. |
11-10-2016, 10:01 AM | #16 |
3442
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
They may not work well in angel eye because they are not matched to the fiber optic tubes.
Angel eyes need to be viewed at least 20 feet away to get an accurate depiction of outer ring output, FYI. |
11-10-2016, 12:20 PM | #17 |
BimmerPost Supporting Vendor
471
Rep 4,938
+1. a daytime comparison to the stock bulb would be the most helpful. Night time pictures have no point of reference for brightness
11-10-2016, 10:16 PM | #18 | |
Where'd my VTEC go?
481
Rep 6,067
There is a thing called beam patterns and cutoffs. A fog light beam should not be shining any significant amount of light higher than the fog light itself. Fog lights are meant to be aimed low to light up the foreground.
