M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > BBS FI R Question
      03-10-2017, 07:26 PM   #1
UltraMagneticAL
Meh
UltraMagneticAL's Avatar
928
Drives: M3CS & Cayman S
2019 BMW M3 CS  [0.00]
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
BBS FI R Question
3/4 of my wheels came in (boo to the missing wheel). i also got a hardware package for centering rings.
the center bore on the wheels are marked 72.5mm, which is what i would expect. i'm wondering why i got an extra hardware kit that has the same center bore?
should i not use the hardware kit?
      03-11-2017, 08:55 AM   #2
bignico_05
Drives: aw 135i m sport
I'm sorry I'm not really able to answer your question properly and will now ask you another question.
Are you putting these wheels on a M2 and if so, what size tires are you using?
      03-11-2017, 12:27 PM   #3
alexc93
Drives: na
Detailers domain are running BBS FI-R's on their M2. I'd recommend asking them about this!
      03-11-2017, 02:22 PM   #4
UltraMagneticAL
Meh
928
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
here you go
      03-11-2017, 02:57 PM   #5
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Originally Posted by UltraMagneticAL View Post
here you go
He asked about the tires.
      03-11-2017, 04:45 PM   #6
UltraMagneticAL
Meh
928
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
here you go
you right. read the question too fast.
going with stock tires for now, then when they wear out, probably look into a bit beefier tire.
      03-11-2017, 05:49 PM   #7
alexc93
Drives: na
I believe the detailers domain car had beefier tires but caused slight rubbing in the rear so they went back to stock tires.
I did a lot of digging on their setup a few weeks back lol.
      03-11-2017, 07:44 PM   #8
bignico_05
I think he was slammed though
      03-11-2017, 07:46 PM   #9
bignico_05
I'm looking to get myself a set but unsure what to do. I kind of don't want to drop that much money and have to stretch out the stock tires. Hopefully if you're lowered on BMW's M performance coilovers at the recommended setting we could go with a 255/275 setup and have no issues.
      03-11-2017, 07:58 PM   #10
UltraMagneticAL
Meh
928
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
i'm on kw v3 and not slammed all the way. pretty sure i will be okay when its time to replace tires and go wider.
      03-11-2017, 08:00 PM   #11
bignico_05
Ya you're probably right, I think I'll give it a go eventually. It will look sick bro congrats!
      03-17-2017, 03:28 PM   #12
bignico_05
So any updates? Did you put them on the car?
      03-17-2017, 03:57 PM   #13
UltraMagneticAL
Meh
928
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
i don't have the 4th wheel yet
      03-17-2017, 08:31 PM   #14
bignico_05
Ah true, it's weird they sent out only three wheels
      03-21-2017, 10:37 AM   #15
Rudy@tirerack
Moderator
123
Drives: rudy@tirerack.com
The center rings were most likely put in the box by mistake. You should not need those. In fact, if you try to install the wheels with the rings, they will not fit over the hub.
      03-27-2017, 07:27 PM   #16
Detailers Domain
BimmerPost Supporting Vendor
Detailers Domain's Avatar
Drives: 20 M2C / 22 X3MC
I went back to stock set up guys, will probably do an alignment to get some more camber and see if I can zero out the rubbing, I'm slammed so even on stock under heavy load I will rub, that's 600 lbs extra in my car going over some very uneven payment and dips in the road. (NY/NJ/CT/PA) roads suck LOL
m2
