03-31-2017, 11:59 AM | #1 |
Rep 542
Steering wheel vibration under braking
Hey guys,
I do realize this probably has been brought up before, but I am going to ask again.. I recently have noticed a slight vibration through the steering wheel, on braking. Only occurs when braking from about 60mph to 40mph. Disappears at lower speeds. Some details- I have a 2016 M2, approaching one year ownership (woohoo), and currently have about 4400 miles on it. Lowered on H&R springs (for about the past 5-6 months). No spacers. I just started noticing this phenomenon. Now, I never got an alignment after the springs settled, since the car's been in hibernation mode up until now. Also of note, I had minor curb damage repaired to my driver's side front wheel several months ago. But it was very, very minor. I can't imagine my wheel not being straight; I can't imagine bad rotors. The car pulls straight. Coasts and accelerated smoothly. If I lost a wheel weight, I would assume I'd have more constant symptoms??? Anyways, anyone have any thought? Thanks in advance -c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock 2008 Acura RDX-stock 2005 Honda S2000-mostly stock 1994 Nissan 300ZX Twin Turbo-barely stock |
04-03-2017, 11:07 AM | #3 |
Rep 3,714
Probably pad deposits. Did you run your stock brakes fairly hard and get them hot? The OEM pads don't stand up well to heavy canyon carving/track use and you can get an uneven pad wear layer on the rotors which makes the surface wavy and feel like you have a warped rotor.
pup73516.50 |
04-03-2017, 01:53 PM | #4 | |
Rep 542
First things first; I need to get an alignment. Then we'll go from there. Thanks for the input. I'll post with any updates -c
04-03-2017, 05:11 PM | #5 | |
Rep 3,714
Alignment should have nothing to do with vibration. If it's under braking only it's the brakes. If it's vibrating all the time or at certain speeds it's probably a wheel balance issue. |
pup73516.50 |
04-03-2017, 05:30 PM | #6 |
Rep 61
Interesting,
I just had my front rotors and pads changed after feeling the same vibrations. I did go to the track but I am still surprised that the rotors wrapped this easily. BMW dealer only mentioned everything overheated and needed to be changed. |
pup73516.50 |
04-04-2017, 07:14 AM | #7 | |
Rep 542
-c
04-04-2017, 08:21 AM | #8 | |
Rep 3,714
I was talking to a brake engineer for a major supplier at COTA and he told me modern iron discs are very difficult to actually warp. I thought I warped my rotors but ended up being pad deposits from running stock and then track pads on top causing an uneven wear layer. I used a rotor hone to clean off all the deposits and re-bedded pads and it was fine. |
04-04-2017, 11:49 AM | #9 |
Rep 61
You guys are most likely right. My dealer changed everything for free without even asking. My technician only mentioned that the brakes overheated, he never truly said they were warped. They changed them for free but made it clear that this is not covered by the warranty and they would not do this every time.
So this leads to this question : how to avoid pads deposit? I did respect all my cooling laps, did not use the parking brake, ... |
04-04-2017, 05:36 PM | #10 | |
Rep 245
Drives: M2 DCT MPerformance coilovers
04-05-2017, 06:29 PM | #11 |
Rep 61
I will for sure upgrade to new pads for my next track event. Not quite sure yet which brand I will go with. Pagids seem to be the most popular ones but I am still looking at all options, including pads that are not as track oriented like the Porterfileds R4s
05-06-2017, 06:03 PM | #12 |
Rep 1,608
'Warped' rotors is pretty much a misnomer these days. Consider it synonymous with pad deposits.
Ive been able to smooth things out often times by rebedding.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 |
05-07-2017, 09:48 PM | #13 | |
BimmerPost Supporting Vendor
3857
Rep 54,416
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
05-07-2017, 11:34 PM | #14 |
Rep 120
My bet on the OP's issue is a flat spot on the tires from sitting around all winter. Maybe a bad wheel bearing too. It doesn't take much of a curbing to ruin wheel bearings.
05-08-2017, 07:28 AM | #15 | |
Rep 542
Thanks alot -c
05-20-2017, 08:22 PM | #16 |
Rep 4
Incorrect, since about 1/17 we now turn rotors. But typically not drilled rotors because of the bmw approved on car brake lathes we use.
05-21-2017, 07:13 AM | #17 | ||
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
09-09-2019, 01:14 PM | #19 |
Rep 267
09-10-2019, 12:35 AM | #20 |
Rep 1,823
The solution is to keep the track pads in and drive with them for an extra week or so after your track day. When they are cool they become more abrasive and will scrub the uneven deposits off the rotors.
Bring your ear plugs. You can also use sand paper and scrub off the surface deposits that way. |
09-10-2019, 02:08 PM | #21 |
1026
Rep 842
Gents,
You're dealing with uneven pad deposits. The videos below should help you work your way through this issue, and help prevent it it in the future. If the deposits are very mild, just driving around with the brakes cold could clean them up. If not, cleaning up the discs with a scotch brite pad could do the trick. Or, if you have a set of track/race pads on hand, install them and drive around cold. That will peel the pad transfer layer off in a hurry (as in the video below). If that doesn't work, the next resort would be getting the discs resurfaced on a brake lathe. If the deposits are really bad, they may not be repairable. That is usually not the case in our experience however. One of the above typically gets the job done and eliminates your judder. |
MDIGGITY53.50 |
09-10-2019, 11:21 PM | #22 |
Rep 199
As someone who just finally cleaned off pad deposits by running race pads for a few weeks I would think it is almost certainly pad deposits from heavy braking ie track time or super heavy sport driving. How many miles were on your car when you picked it up?
2017 BMW M2 BSM 6spd with Fabspeed/HJS 300 cell Sportcat, BM3 OTS Stg 2 tune, Dinan Turbo, MST V2 Inlet, Dinan IC, Dinan CAI, Ohlins, Carbon Fiber+Aluminum Strut braces.
2007 BMW 335i (sold); 1997 BMW E36 M3 (sold); 1988 BMW 535is (sold); 1984 BMW 323i Alpina (can't believe I sold),1969 BMW 2002 Ti (spec'd as Ti; and yes I sold this too...). |
