BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Coding: BDC_BODY2
      06-22-2017, 06:12 PM   #1
cwhands
Drives: F80 M3 SS/CSAT 6MT
Coding: BDC_BODY2
Anyone have insight on properly reading BDC_BODY2?
With Esys 2.7.1 and PSDZ 61.4 it still only shows a bunch of periods next to everything and no details. Who has successfully gotten into this for coding?
      06-22-2017, 10:10 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
You need to either update your Launcher or, if you are using Premium, select correct chassis. I do not have trouble reading any G012/G030 ECU.
View post on imgur.com
      06-24-2017, 10:30 AM   #3
cwhands
I tried using two different versions of the launcher and updated prior to making the post, am using PRO, and this is the latest PSDZ afaik...do you have any other suggestions?
There are 4 CAFDs in BDC_BODY2, (17BC, 17BD, 1DF7, 1DF8) the only one that shows periods and no functions is CAFD_000017BC_103_036_153, others load up fine. The CAFD shows up in my files.
      06-24-2017, 01:24 PM   #4
Almaretto
Almaretto's Avatar
2374
PSdZ is unmapped and updating will not help unless you get "not found [C012]" errors when "Read Coding Data."
I am aware there are 4 CAFD's and you should be able to read them all. Depending on I-Step, parts are unmapped, but the majority are mapped and you should not see only periods. For complete CAFD_ID list, see here.
The only solution I know is using latest Launcher software (ie 2.7.1). Here are images from E-sys and NCD / CAFD Tool for what you should see:
cwhands640.00
Drtjxtz160.00
      06-24-2017, 01:41 PM   #5
cwhands
Thanks for your help Almaretto. Got the CAFD to stop showing periods after a couple attempts reconnecting to the car. That said, a lot of the values still come up as "unmapped value" Any idea what causes that? That CAFD list is helpful, too. Thanks again.
      06-24-2017, 02:08 PM   #6
Almaretto
Almaretto's Avatar
2374
Launcher uses legacy data to map PSdZ. So, as new FDL's are added, functions move around, leaving both incorrect/invalid and unknown data.
Mapping currently is based on P3.59.4 I believe. We are left either making educated guesses and/or waiting for TM to update.
cwhands640.00
      06-29-2017, 11:59 AM   #7
bimmereason
bimmereason's Avatar
Drives: G05 X5 40i, F10 535xi, F26 X4
I am using Launcher 2.7.1 Pro with 61.4 PSDZ, BDC I read from my car shows like this and I am not able to locate where "FLC_Aktiv" is, my headlight is not able to be turned off (even in switch "0") when it is dark. That is very annoying P.S. Not mine G12, I got a the other G30 in my hometown.
      06-29-2017, 12:35 PM   #8
Almaretto
Almaretto's Avatar
2374
Mapping is based on legacy files (~P3.59.4). Therefore, as new functions are added (changing bitmasks/moving FDL's around), ECU's start having unmapped regions. This is the case with BDC_Body in G012/G030 starting in 3.61.x.
FLC_Aktiv is present and can be found by reading comments or simply VO coding certain options.
EDIT: Position 0 is DRL. Lighting is in FLM.
      07-04-2017, 04:26 AM   #9
Motorboat411
Drives: BMW 535i
I'm seeing the same issue BUT intermittently. I have PSDZ 61.5 Lite and Latest version of E-sys.
Also, couple of times when I clicked on "Edit FDL" then E-sys crashed without any error messages.
      07-16-2017, 04:48 PM   #10
samovog
Drives: BMW G30 520xd
HI!
I am also having a problem with only the dots showing... I am using Launcher Premium 2.7.1 and data files 62.1... When i start the laucher i select G030 chassis, for coding i select S15A...
What am i doing wrong ?
Thanks,
      07-17-2017, 12:55 PM   #11
Almaretto
Almaretto's Avatar
2374
Originally Posted by samovog View Post
HI!
Thanks,
That should work. You can also try G11 or G12.
      07-18-2017, 10:22 PM   #12
zilch
Drives: G30 520D
I am also having a problem with only the dots showing when I set high memory in launcher premium.
When I set medium it is ok.
However when I set medium and then read 17BC@BDC_BODY2 of G30, edit, save and then code FDL there is be out of memory error.
I'm using E-Sys 3.27.1, Launcher Premium 2.7.1 and PSdZ 3.62.1
      07-19-2017, 06:01 PM   #13
Almaretto
Almaretto's Avatar
2374
E-sys uses Java contiguous memory and BDC is a large module. So, you sometimes have to close and reopen E-sys to clear out to complete desired functions. You can also delete, or temporarily move, unneeded KISWB.
      08-05-2017, 05:20 AM   #14
samovog
Does anyone know how to disable ASS ? I cannot find tcmaster values in BDC BODY... I compared the files with my brothers F15, but no luck... Any help would be appreciated.
Thanks,
      08-05-2017, 05:23 AM   #15
samovog
Tried with memory set to "medium" and it worked fine then
But still: I cannot find the values to either disable ASS or set it to "last used setting". Bummer...
      08-05-2017, 11:00 AM   #16
Almaretto
Almaretto's Avatar
2374
Setting is not in BDC_Body.
      05-17-2019, 03:46 PM   #17
bobbyggx
Drives: '18 BMW G30 540i xDrive
Hi guys,
I have been fighting with this BDC unmapped sections and it seems like I cannot get it to work.
I have reinstalled java allowing the Launcher to run with 4GB ram (this solved the memory issue) but all of the folders are appearing with '.' (screenshot enclosed).
I am using E-Sys 3.30 with Launcher Pro 2.8.1.155 with latest datens and success is 0. Tried dozen of times to restart (application as well as windows), reread the module, open the CAFD in the FDL editor - nothing worked.
The rest of the modules are appearing fine.
      05-17-2019, 04:51 PM   #18
Almaretto
Almaretto's Avatar
2374
Originally Posted by bobbyggx View Post
Hi guys,
That is not mapped in 2.8. You need 3.x for mapping.
      05-17-2019, 07:55 PM   #19
bobbyggx
Thanks, will go for the update.
I have read a lot of threads and I saw people with Launcher 2.7 even having the BDC mapped and was struggling why I cannot make it run
      05-18-2019, 12:44 AM   #20
Almaretto
Almaretto's Avatar
2374
17BC, maybe. But, for 5FA9, you need to update.
5post
