BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Vgate iCar 2 wifi question
      07-06-2017, 12:16 PM   #1
Jbapckfan
Drives: 2018 M550i xDrive
Hey guys, my first attempt at coding is not going well. I purchased the vgate iCar 2 (wifi) and bimmercode and bimmerlink apps. I plugged in the iCar device to my obd port and can see "vlink" on my iphone wifi and can connect to it but then the bimmercode app does not think I am connected. I am currently away from home staying at a hotel, not sure if that matters....does the iCar device also need a wifi connection or does it just use wifi to connect to thr phone.
Feeling like I am missing something here. Several reviews on Amazon say people were coding within 5 minutes of opening the box. Any help appreciated. Car is a 2018 M550i.
      07-06-2017, 12:40 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Some also reported they got bad devices and had to reorder. Once they got functional device it worked. There is some slow setting that you enable as well. Make sure engine is running.
      07-06-2017, 12:56 PM   #3
daveschroeder
Drives: 2017 F06 650i GC
I have the same setup as you (and same car), and mine "just worked". When the adapter is plugged in to the ODB port, its Wi-Fi SSID appears. I connect to it from my iPhone, and then launch Bimmercode or Bimmerlink — in my case it wouldn't connect successfully unless the engine was started (even if it was in "accessory" mode).
      07-06-2017, 02:19 PM   #4
Almaretto
Almaretto's Avatar
2374
Can you code any modules besides HU_NBT2?
      07-06-2017, 02:38 PM   #5
Jbapckfan
Since I can see the SSID I am assuming the device it is not defective. Will restart iPhone and turn off Apple Carplay in the car as that might be interfering and try again tonight. My engine was on last time I tried, so that is not the issue.
      07-07-2017, 10:25 AM   #6
daveschroeder
Right now it is just:
Active Sound Design (ASD_01)
Headunit (HU_NBT_EVO)
Rear Functions Module (HKFM2)
...but the author says more are "coming soon" for all G Series.
Almaretto2374.00
      07-07-2017, 10:36 AM   #7
Almaretto
Almaretto's Avatar
2374
ASD and HKFM2 is new; though also used in other F-series chassis. Hopefully BDC_Body (4) and a few others come soon. For the G12/G30, these are the main coding ECU modules:
  • BDC (CAFD_000017BC, CAFD_00001DF7, CAFD_00001DF8) - Main ECU with many functions
  • HKFM2 (CAFD_00002098) - Trunk
  • IHKA (CAFD_000022D3) - HVAC
  • ACSM (CAFD_00001B29) - SEAT
  • KOMBI (CAFD_00002660) - Instrument Cluster/HUD
  • HU_NBT2 (CAFD_00001EF6) - Head Unit
  • SAS10 (CAFD_00001C7A) - Driver's Assist
  • SM2 (CAFD_00002259) - Seat
      07-07-2017, 11:36 PM   #8
Jbapckfan
It worked for me after I restarted my phone and turned off Apple CarPlay. Does the vgate device have to stay plugged in for the coding changes to remain active or can you code and unplug the device?
      07-07-2017, 11:41 PM   #9
Almaretto
Almaretto's Avatar
2374
You do not have to leave device plugged into vehicle.
      07-08-2017, 07:41 AM   #10
Jbapckfan
Thank you
      05-17-2019, 06:52 AM   #11
bobbyggx
Drives: '18 BMW G30 540i xDrive
Does the Gxx series require WiFi connectivity or BT is also fine? Vgate iCar 2 Pro works in G30 and BimmerCode to code different modules?
      05-22-2019, 12:15 AM   #12
SF_E60
Negotiator
SF_E60's Avatar
Drives: E60 M5 (LCI), i3 BEV
2015 BMW i3 BEV  [0.00]
2009 BMW M5  [0.00]
+1 Would also like to know.
      05-22-2019, 12:37 AM   #13
Almaretto
Almaretto's Avatar
2374
It is adapter specific.
      05-22-2019, 01:26 AM   #14
drjolokia
Drives: 2019 M550i
I can't speak to this particular adapter but I do use a Bluetooth one in my G30
5post
