BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding rear view camera retrofit
      05-03-2018, 04:16 PM   #1
pinguthepenguin
Drives: BMW 530e
Hi All,
I really wish I had rear view camera on my car and spoke to the local dealer who advised that I need following parts:-
66557942742 - Rearview Camera
66212450878 - Retrofit Kit
Both of these come to less than £300
The parts team then looked at the instructions and suggest it will take 4 hours but both the power and data connections are all in boot, has anyone got any experience of this as the labour cost is £530 and I am thinking of going elsewhere
Or even a copy of the instructions?
      05-04-2018, 12:02 AM   #2
Dephead2004
United Kingdom
180
Drives: G30 520i
I suspect you might needed coding too. Dealer only or a friend on here?
      05-04-2018, 03:12 PM   #3
pinguthepenguin
Drives: BMW 530e
instructions
So i managed to get hold of the instructions not as simple of job as hoped!
      08-08-2018, 02:41 PM   #4
KGI
Denmark
Drives: E60 535D , E63 645ci, E10 2002
Yes, this retrofit need to be coded.
      01-28-2019, 02:43 PM   #5
sebica79
Drives: BMW F20
Hello,
I found this topic very useful. I still have a small situation that i would like to clarify with you here. Maybe we could find a solution.
I bought the OEM retrofit kit from BMW AG and separately the camera from a friend with spare parts.
I've started to look into the documentation and confronted with the reality on the car.
When it comes to module Z2 rear right fuse box for the G30, I was not able to see available on the car, the slot Z2*3B where the open cable A3 should be plugged in.
Is there any other connector that needs to be present (the actual Z2*3B) before trying to plug in the miniature connector G? Can I use other location from the rear right fuse box?
I'm looking forward for your answers.
Later edit: Please see the attached file with the fuse box.
Best regards,
Sebi.
      01-28-2019, 06:43 PM   #6
saporitj
Drives: 2019 540ix M Sport
I have the rear view camera but would love to retrofit a front camera. Just asked dealer today and he said not possible because wiring isn't there and coding needed. How did you find part # for retro fit rear? Do you know of a kit for front camera? I'm not trying to get the 3D view but just front camera to work like rear.
US G30 540iX M sport
Thanks
JS
      01-29-2019, 01:59 AM   #7
GaSelle
GaSelle's Avatar
181
Drives: ´23 iX3 M Sport Charged
Thanks
The reverse camera comes as an OEM retrofit kit. I can´t find similar for the front camera.
      01-29-2019, 11:45 PM   #8
saporitj
Thanks
Thank you. I looked around and had the same results. Only thing missing from my car is the cameras 🤬
Oversight on my part. Someone is trying a 3D camera retrofit but a lot of effort. All I want is the front for pulling into parking spaces.
JS
      07-04-2019, 02:17 PM   #9
macmaw
Drives: BMW 520d M Sport
Originally Posted by sebica79 View Post
Hello,
Best regards,
Sebi.
Did you ever get anywhere with this?
I have the same issue
      08-29-2019, 03:06 PM   #10
unclez
Drives: VW
Did anybody manage to install the rear camera?
      09-09-2019, 10:44 PM   #11
macmaw
I have installed mines, but not yet working, suspect a bad connection or coding issue.
      09-09-2019, 10:55 PM   #12
macmaw
Hello,
Best regards,
Sebi.
The instructions show the view looking out from behind the fuse panel, so the fuse you want is the 5A fuse, which has a green wire going to pin 11, this is where you splice the red / violet wire in to - see attached photo where I have marked the fuse you want - remove this fuse panel and you will get access to splice in to the green wire then.
      09-16-2019, 06:38 PM   #13
kubax86
kubax86's Avatar
Drives: M2
It could be eariler version of iLevel, try to upgrade it and it should be good.
      09-17-2019, 01:55 AM   #14
Momo Jch
Momo Jch's Avatar
Drives: BMW F34 330
You can install a full car camera
      10-02-2019, 05:21 PM   #15
kitster
United Kingdom
541
Drives: G31 M Sport
Hi all,
This is one retrofit that didn't come with my car. Should be easier compared to upgrading my F31 from non-Nav + Combox to ProNav. Anyway so it might help others the PDF cable codes refer to:
GN - Green
GE - Yellow
WS - White
      11-20-2019, 11:09 AM   #16
Sasquartch
Drives: 520i G30
Does anyone know how you would code in the retrofit kit (genuine) using eSys ??
Is it just a case of activating parameters (which I'm comfortable with) in existing modules or is it more involved ?
The instructions refer to using ISTA/P I think but would have thought esys should be able to do the same thing.
Any advice welcome
      11-30-2019, 08:04 AM   #17
afi2k
Drives: G30
Hopefully taking delivery of a new G30 m sport in a few weeks time, at the price I couldn't spec any extras. What I would've liked was power fold mirrors and reverse camera, personally think they should be standard features on a premium car.
I can live without the power fold mirrors, but would like to retrofit the reverse camera, came across a kit on eBay https://rover.ebay.com/rover/0/0/0?m...2F254202780386
Does say in description that it's OEM anyone had any experience, I know I have to code it, had an E60 years ago and had ISTA but that laptops knackered now, hoping someone in the Midlands has the kit to code for me and if possible give me a hand in install.
All help appreciated
      11-30-2019, 09:29 AM   #18
kubax86
kubax86's Avatar
Drives: M2
This retrofit is tooooo expensive. You could buy all parts including rear view camera for around 150 USD.
Coding is also easy.
PM me for more.
      11-30-2019, 09:35 AM   #19
Bollywoodkid
Drives: G05
PM me for more.
Does anyone have a picture of how the retro looks?
      12-01-2019, 04:31 AM   #20
afi2k
Drives: G30
PM me for more.
PMed
      12-02-2019, 01:17 PM   #21
thxex
Drives: BMW G30
PM me for more.
Recent G30 purchaser sans reversing camera so interested.
Will PM you for more info.
      12-18-2019, 06:05 AM   #22
macmaw
I think you could be right there. 😁
It was remote coded a while ago, by Bimmertech USA, and didn’t work following that.
It was at the dealership on Monday for a recall job and I asked them to look in to it and check the connections at the BDC plugs as they are tricky to make.
They said they “programmed” it but was still not working and suggested I remove and reinstall, my instinct was still to check the BDC plugs which they hadn’t done.
When I drove the car home.......the camera is now working.
I can only assume this is because a software update was performed also.
It maybe never worked with them as it maybe has to go to sleep for a while, I’m not sure.
I seem to remember the coder telling me to wait half an hour before trying it.
5post
