12-02-2018, 08:36 PM | #1 |
Rep 11
Offset Rims Very Narrow?
Has anyone gained insight to why the rims have been narrowed for the offset options on the GO5 versus the F15? F15 offsets were 10" front and 11" back (11.5" with the 325's) while the G05 appears to be 9.5" front and 10" back (10.5" with the 315 on 22").
Many have commented that the look of the same 315's is anemic from the rear but I'm also seeing these standard tire/rim compatibility charts on line (all the same regardless of source) that suggest both the offset 275 and 315 are too wide for 9.5" and 10" rims respectively - especially the 315's should be on 11.5" as a minimum but probably 12" rims. I'm no tire expert but especially on a 35 sidewall profile it doesn't even seem the rears will be making full proper road contact on a rim almost 2.5" narrower than the tread. Perhaps there is an error in the order guide and the rims are wider than shown? |
12-02-2018, 08:50 PM | #2 |
Rep 790
FYI, the ordering guide wheel size is wrong for the 741M. They are 10.5” in the rear. Below is from a G05 with 741M wheels.
- Scott
Current Cars: 2019 X5 xDrive40i M-Sport, 2018 Camaro ZL1 Past BMWs: '16 528i, '00 M-Coupe, '14 X1 sDrive28i, '00 740iL, '02 325i, '99 M-Coupe, '00 323Ci, '79 323i, '83 320i |
12-02-2018, 08:59 PM | #3 |
Rep 11
Thanks - good news but still seems unusually narrow doesn't it?
My delivery is a few weeks away but I have seen the 741's in person and they just seem so much narrower than the 315's on F15's still on the dealers lot.. |
12-02-2018, 09:07 PM | #4 | |
Rep 790
But I do agree the tires look wider on the F15.
- Scott
12-02-2018, 09:09 PM | #5 |
Rep 294
Nothing anemic about the 315 and 275s on the 21"s
'13 Raptor (sold); '14 Raptor (sold); '15 A6 Quattro (sold); '19 X5 xDrive 40i (sold); '20 4Runner TRD Pro (sold), '22 MDX A-Spec (sold); '22 MDX A-Spec (sold); '24 X5 M60i
12-02-2018, 09:21 PM | #6 |
Rep 6,121
Drives: 2022 Porsche Boxster GTS
After some checking it's rather odd how they're running such wide tires on wheels that aren't up to the task. Surely the engineers at BMW wouldn't make such a simple mistake. I'm willing to be there's more to this story than what's above.
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
12-02-2018, 09:22 PM | #7 |
Rep 5,457
If I look up say p zero tires 315/35-21 it indicates rim can be 10.5”-12.5”
SIZE UTQG MAX. LOAD MAX. INFLATION PRESSURE TREAD DEPTH TIRE WEIGHT RIM WIDTH RANGE 315/35ZR21 (111Y) XL N0(Porsche) 220 AA A 2,403 lbs 50 psi 10/32" 32 lbs 10.5-12.5"
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
12-02-2018, 09:31 PM | #8 |
Rep 790
The tires appear to fit the 741M wheels perfectly. They don’t look out of place or like they barely fit.
- Scott
12-02-2018, 10:20 PM | #9 |
Rep 6,121
Yeah, some tires fit the 10.5" wheel others do not from what I found. It appears that you just need to check beforehand when buying non-OEM RFTs or non-RFTs
12-03-2018, 08:16 AM | #10 |
BMW Client Advisor
3459
Rep 2,504
Drives: 2020 M340i
Wait what?
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
12-10-2018, 10:20 PM | #11 |
Rep 60
I was wondering if somebody can take a picture of their staggered 21" or 22" tires from rear showing 315 tire width on 10.5J offset (similar angle to the ones below - not mine but it's the exact same setup I have). I absolutely love the look of 315s on my E70.
Also, I am not sure if anybody seen the new GLE 2020, it appears it’s getting staggered setup as well, not sure how wide the rears are (GLE image below). I wonder why BMW didn't keep 11J with G05 considering the vehicle has grown in dimension all around. Last edited by smarty; 12-11-2018 at 02:11 AM.. Reason: Removed Benz tire width guess |
02-17-2019, 10:34 PM | #12 |
Rep 85
G05 M-sport wheels
I think the wheels/tires on the e70 M-sport from the rear look considerably more aggressive than the wheels/tires on G05 M-sport.
If you compare the width of the 20" 333M to the 22" 742M the difference is only a 0.5". I guess I can see how with the 22" wheels being obviously taller it can dilute the look of a "boxier" 20" wheel but I don't know. Those 333M wheels just looked mean. Maybe someone with knowledge and experience in the matter could shed some light... |
02-17-2019, 10:42 PM | #13 |
Rep 6,121
Here you go. I can take some one's specially showing the wheels tomorrow if needed
