Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Laserlights retrofit
      04-11-2019, 06:30 AM   #1
Hojbjerg
Denmark
Drives: BMW G20 320d
Hi
Has anyone thought about retrofitting the laserlights?
Is it plug and play with just some coding?
      04-30-2019, 02:58 PM   #2
larrybml
Drives: X3 F25 2011
I think that is too soon. It will be very interesting thread, but after one year I think!
      05-03-2019, 02:40 PM   #3
Calamari
Drives: 2024 G21 330d, 2008 E87 118i
Originally Posted by Hojbjerg View Post
Hi
Laser lights is certainly not plug and play retrofit since Laser lights have selective beam and require additional controllers and optical sensors in order to work.
As an experienced software developer (with a lot of background in electronics), I would say it's almost impossible to retrofit Laser lights reliably without significant time and money investment. In fact, the cost will be ridiculous. Just check the price of a single laser headlight.
Even if you perform this retrofit with OEM parts, there is a high risk of defects and bugs that will manifest after the retrofit since the car was originally equipped with different type of headlights controller.
In short, not worth it cause I found Adaptive LEDs work great.
      05-04-2019, 05:03 PM   #4
TBGaming
Italy
Drives: M340i xDrive
Laser headlights are indeed plug and play. I checked the wiring with ISTA and it is the same between all the headlight versions, which is a big step forward from all the different harnesses in the f30. If you want to retrofit them you need the headlight plus their modules.
Mb7328831.00
      11-22-2019, 10:55 AM   #5
newest5
Drives: bmw e91
just need coding 5AZ
      11-22-2019, 06:07 PM   #6
Mb73288
Drives: 2019 bmw 330i xdrive
This shop seem to be doing the retro fit already for laser lights
https://www.facebook.com/groupbuycarparts/
      11-23-2019, 06:35 PM   #7
SCardamon
SCardamon's Avatar
Drives: 2019 330i
Want
      10-04-2023, 06:48 PM   #8
pcp1234
Drives: G03
Yes it can be done. Car must have kafas camera/s for start.
Another point is if vehicle is equipped with hba option. If not, that must be retrofitted too. Most cars will need certificate from connected drive store which can be arranged too. If you are lucky not required.
Last step fit headlights and code
g20
