Bimmerpost
4 Series
Technical Topics B48 4-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Keeping the exhaust valve open?
      12-09-2019, 10:36 PM   #1
chunll2001
chunll2001's Avatar
Drives: 2018 M5, M3 ZCP, M3 CS
2021 BMW G80   [0.00]
2018 F80 ZCP  [0.00]
2018 BMW M3 CS  [0.00]
2018 BMW M5  [0.00]
Question Keeping the exhaust valve open?
Hey all!
Is there anyway to keep the exhaust always open while not needing to be in manual sport mode? The right exhaust only opens after driving around a while in manual sport mode or being in park/ neutral also in sport mode.
I would love to drive around while being in comfort mode with the exhaust open.
I have seen people unplug the exhaust valve plug on previous generations while the exhaust is open to prevent it from closing after pulling out the plug.
UPDATE : For those wondering how it sounds, its a bit louder in both Eco/comfort modes ( sounds the same in both modes ), though you still only get the pops in sport mode.
Feels great to always have the pops in sport mode without having to be in manual and having to go past a certain RPM to keep the flap open. I've noticed before this mod that if I drove in sport mode & manual that doing lots of down shifting would lead to the flap opening, however if I stop doing that for even under a minute the flap would close again.
Procedure : Start the engine, wait a bit and while in Park switch to sport mode and you should hear the flap open. While engine is on ( as I believe while the engine is off the flap closes) go to the rear right bottom of the car to unplug the plug. There should be a little tab to push in in order to get the plug to come out. Pulling the plug really hard won't do anything until you push the little tab to loosen the whole plug. Tape it up and I would suggest zip tying the whole connector along the valve switch.
similar to what we're doing however on the G20 it's on the right exhaust and also having the car off doesn't have the flap open.
Attached images show before and after.
For the connector I taped it up and zip tied it to the bracket. And also taped up the plug and put a zip tied around it to make sure the tape stayed on there and as some more protection.
      12-09-2019, 11:17 PM   #2
chenry
Drives: BMWs
I am under the impression that is still an option for you - was another thread on this quite recently
Mark_R10.50
      12-09-2019, 11:47 PM   #3
premier3is
premier3is's Avatar
1632
Drives: 2019 BMW 330i M-Sport
Would love to know as well. I was just thinking another this a few days ago since a buddy of mines did this on his E92 by pulling a fuse I believe.
      12-11-2019, 03:09 AM   #4
areoqs
Drives: G21
Guys, i picked my G21 330i last friday. Is exhaust after 7.2019 (new dB regulations) quiter only by software or also OPF affects the tone of exhaust? My car sounds like shit. I drove dealer car on may and i love it on sport/sport+
      12-11-2019, 03:53 PM   #5
JohnBarny
Drives: BMW F36 420d + G21 330i
I have the same mate, my mates July 330i sounds ace but my October build 330i sounds shit no burbles either
      12-11-2019, 04:16 PM   #6
dejansokolovski
Drives: BMW 330e G20, BMW 520D F11
It's the same here, mine is July build however I think.. But on the otherhand it's a 330e. That's why I thought BMW killed the burbles/pops et.c on purpose because it being a 330e, but maybe it then has to do with with when it was built rather than being a 330e vs 330i/320i et.c..
So it's all in the tune then I guess? I've changed rear muffler to a custom built and that didn't bring any burbles forward, just a bit louder.
      12-11-2019, 05:10 PM   #7
Preciseyyc
Preciseyyc's Avatar
Drives: F15 35i G20 m340
Get it open in sport mode. Unplug valve. Tape end to
Protect it. Done
      12-11-2019, 09:16 PM   #8
chunll2001
chunll2001's Avatar
2021 BMW G80   [0.00]
2018 F80 ZCP  [0.00]
2018 BMW M5  [0.00]
Protect it. Done
Just did it today too!, did you use electrical tape on both ends of the plugs? That's what I did today, though I feel like there need to be a better solution than just the tape. I see your location is in Canada so I'm assuming lots of snow? Do you think the tape is fine for the weather there?
      12-11-2019, 09:20 PM   #9
Preciseyyc
Preciseyyc's Avatar
Protect it. Done
Nah just the male end then pushed it back into the valve connection
      12-11-2019, 09:47 PM   #10
chunll2001
chunll2001's Avatar
2021 BMW G80   [0.00]
2018 F80 ZCP  [0.00]
2018 BMW M5  [0.00]
So you put tape on the connector one and plugged it back in?
Little confused here
      12-11-2019, 09:49 PM   #11
Preciseyyc
Preciseyyc's Avatar
Yea exactly. Then its "in place"
But not making connection; protects both connections, did the same on my f32 and f15.
      12-11-2019, 10:10 PM   #12
chunll2001
chunll2001's Avatar
2021 BMW G80   [0.00]
2018 F80 ZCP  [0.00]
2018 BMW M5  [0.00]
Hmm I see now. But it doesn't really plug in correct? Both are just lined up together but taped between each other to prevent the plugs from being connected?
As in a piece of tape between the two plugs to prevent a connection from occurring if that makes it more clear.
      12-11-2019, 10:25 PM   #13
Preciseyyc
Preciseyyc's Avatar
Yea I wrapped the male end with tape. It keeps it from connecting, but having it still together keeps the plugs protected
      12-11-2019, 10:29 PM   #14
chunll2001
chunll2001's Avatar
2021 BMW G80   [0.00]
2018 F80 ZCP  [0.00]
2018 BMW M5  [0.00]
Ah I see now. Might do the same later on.
Currently its the same as yours but just not " together" with the connector being zip tied to the bracket while still covered up.
Thanks for the tip!
      12-11-2019, 10:31 PM   #15
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
Noob question. How do you unplug the connector? Does the car have to be raised on lifts? Are there any errors/CELs on the dashboard/MMI?
      12-11-2019, 10:36 PM   #16
Preciseyyc
Preciseyyc's Avatar
Thanks for the tip!
Exactly. No worries.
No errors, shadow codes if you check codes. But no CEL or anything else.
Just start the car, get it in sport mode, wait for valve to open. Lay under it squeeze the release tab and pull it out.
Or loosen the plug before starting it if you're worried about exhaust in your face
VipinLJ1944.50
      12-11-2019, 10:58 PM   #17
chunll2001
chunll2001's Avatar
2021 BMW G80   [0.00]
2018 F80 ZCP  [0.00]
2018 BMW M5  [0.00]
It was a bit hard for me to find the “ tab” to push for the connector to slide right out so I put my car on a lift and it became so much easier as I wasn’t laying on the floor haha. No errors on the dashboard. It was like it never even happened.
VipinLJ1944.50
      12-11-2019, 11:18 PM   #18
VipinLJ
Petrolhead
VipinLJ's Avatar
Thank you so much guys. I’ll have to wait till I go to my cousins house where his driveway has a defect that makes it act like a built in jack. I’m claustrophobic so that doesn’t help
      12-11-2019, 11:20 PM   #19
Preciseyyc
Preciseyyc's Avatar
It's right at the back dont even need to be under the car it's 2" back from the tips you'll see it right away, just reach up and it's there literally took me a minute including taping the plug end off
VipinLJ1944.50
      12-11-2019, 11:56 PM   #20
VipinLJ
Petrolhead
VipinLJ's Avatar
Thank you once again. Looks like it’s going to be warmer here tomorrow and it’ll be the perfect time to do it then.
      12-12-2019, 07:54 AM   #21
areoqs
Drives: G21
It works for me. Latest software, no errors - but no burbles.
      12-12-2019, 07:57 AM   #22
chunll2001
chunll2001's Avatar
2021 BMW G80   [0.00]
2018 F80 ZCP  [0.00]
2018 BMW M5  [0.00]
You have the touring model correct? Saw a thread where many don't the burbles at all even in sport mode on the touring model. That really sucks. Do you think you would reconsider buying the car if you knew it didn't have any burbles and pops?
Tags
exhaust, valve
g20
