05-18-2020, 03:31 PM | #1 |
Rep 24
Is there a way to lock the key-fob in the car?
I'm trying to figure out the best way to secure my car (and electronic key fob) while going sailing. I've thought about a lock box I can secure to the outside of the car, but the proximity to the vehicle would trigger an unlock if someone grabbed the door handle. I do have comfort access so presumably I could take the key card with me if I could disable the fob temporarily
Any thoughts? |
05-18-2020, 03:36 PM | #2 |
Rep 22
Isn't the key card intended for these types of situations where you don't want to get the fob wet? I'm not sure why you'd need to take both the fob and the key card when the card can take its place for all car functions.
05-18-2020, 03:45 PM | #3 | |
PWRDBYM
36
Rep 76
I used to use a bag like this when I did Turo; customer would put key in bag and lock the door manually and close...Blocks the key signal. |
05-18-2020, 03:54 PM | #4 | |
Rep 2,499
05-18-2020, 04:03 PM | #5 |
Rep 87
You can pick up a small dry bag. I'm a kayaker and just keep the key in my pocket when I'm wearing my dry suit but switch to a drybag when the water is warmer.
05-18-2020, 04:13 PM | #6 |
Rep 101
Are the new cars different? I have a E92 and lock the key fob in there all the time when I do a open water swim at the lake. I remove the key from the key fob, place the key fob in the drivers door, then manually lock the car with the key. I have had the alarm go off a couple times while unlocking it, but 95% of the time it works without the alarm going off.
Please let me know if this works, I may reconsider buying a G20 if I can't remove the key and lock the door. Doesn't the new car have a proximity that you can turn off? |
05-18-2020, 08:47 PM | #8 |
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
Leave the fob at home use the card key and lock your phone in the car.
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
Preciseyyc162.00 |
05-18-2020, 09:42 PM | #9 |
Rep 38
I read somewhere the other day that there's a couple of dead spots inside the car where it doesn't detect the key fob (like the glove compartment). I haven't personally tested but worth trying. Otherwise faraday bags would work to block the signal like others mentioned.
05-18-2020, 09:46 PM | #10 | |
Rep 254
Drives: BMW M3 Comp Xdrive
05-19-2020, 08:04 PM | #12 | |
Rep 13
05-20-2020, 08:36 PM | #13 |
Rep 1,509
05-21-2020, 06:59 AM | #14 |
X3M Comp is a beast
89
Rep 171
I turn off the car put the key in the center armrest then use the Digital Key to lock the doors. Once back to the car i use the digital key to unlock the car then I believe I had to lock unlock the car to allow the fob to work. I do it at car meets so the car does not lock and unlock every time I get near it. and then its stays locked.
05-21-2020, 09:07 AM | #15 |
Rep 101
05-21-2020, 10:26 AM | #16 |
Rep 101
I just took my wife's 535d in for service an have a G20 330i loaner car. Just did the test that I use on my car and it works. Take the key out of the fob, place the fob in the drivers door and manually lock the car with the key. I turned off proximity before trying this. It works, I could not unlock the car with the handle, I had to manually unlock it with the key first. The only bad part is you need to remove the plastic key cover and I needed a very small screwdriver to pop it out, looks ugly when it's removed.
