BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Anyone DIY spark plugs yet????
      06-02-2020, 07:09 PM   #1
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
I can't find any videos on this for the F90. There are some for the prior model. Does not look that bad, but have to move a ton of stuff out of the way. Trying to decide to DIY or have dealer do it. 25k service.
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      06-02-2020, 07:51 PM   #2
Demon Barber
Drives: 2018 M5, 2022 911 Turbo S
I also want to do this myself, but it looks worse than the F10 as far as getting stuff out of the way.
      06-02-2020, 07:54 PM   #3
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
I figured by now someone would have posted some images....I guess it will be me...
Took down my RS6 myself to do the plugs and coils.....timing belt is a PITA. LOL.
Mike
      06-02-2020, 08:04 PM   #4
DocWeatherington
DocWeatherington's Avatar
Drives: F90 CP
23 Bmw M3  [10.00]
Mike
I haven't seen anything but, aren't the spark plugs including during the first 3yrs 36k for original owner? Not sure what the service manual states.
Same motor minus a few revisions as F10. How much is your time worth and what does the dealership charge lol? Certified independent shop maybe.
      06-02-2020, 09:22 PM   #5
Demon Barber
Yeah it seems like it should be offered in the first 3 years, but I can't find an answer about when they should be changed. It's also fun to turn the wrenches yourself and know it was actually done and done correctly.
      06-03-2020, 06:13 AM   #6
DocWeatherington
Drives: F90 CP
23 Bmw M3  [10.00]
Aronis
If memory services me correct normally at Inspections I & II or every third oil change for M cars they recommend plugs ( 3yrs or 30,000 miles whichever comes first).
I'm going to ask tomorrow as I'm going in for the 1st year (or 8K) oil change.
      06-03-2020, 07:56 AM   #7
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
It’s covered. But I like DIY.
Mike
      06-03-2020, 10:48 AM   #8
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
FOUND IT! LOL
https://www.newtis.info/tisv2/a/en/f...ugs/1VncPuvtU2
Now I know what needs to be moved, removed, etc.
Mike
      06-03-2020, 02:08 PM   #9
Demon Barber
FOUND IT! LOL
Mike
It's great that you found this. Looks like it's just about as involved as a spark plug change could be, unfortunately.
      06-03-2020, 02:23 PM   #10
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
Yes, but less intimidating than without a guide. Interesting 'engineering' that requires so much disassembly for a routine q25k mile spark plug swap over. The coolant tank thing is just dumb. I guess the dealers have a stock supply of replacement plastic clips and connectors ready for 'routine' service on these cars when they are 5 or 6 years old and have had those clips undone a few times. I just wonder if you can get away with just moving the coolant tank up without removing completely. The rest of the plastic covers and ECU modules are no big deal. At least you don't have to remove the air boxes like you do in the F10.
I was looking at another breakdown sheet, on a different page of the same website, and they showed how to remove the coolant tank on the passenger side also. This breakdown does not mention it? I think it may be in error?
I'll poke around this weekend, I took a quick look a few times, but as usual something else called me attention.
At this point I am toying with keeping this car for 10 years and want to know if I can DIY for the routine stuff. Next thing to consider is the timing belt service. Those routine must be done things are different than the fix a broken part deals which would be covered by an extended warrantee.
Mike
      06-03-2020, 02:27 PM   #11
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
This "special tool" is simply priceless. Look at the name of it.
"Original Rubber Hose." This is the Original Rubber hose that was used to beat people back in Germany.
      06-03-2020, 03:41 PM   #12
Demon Barber
Haha, the "original" rubber hose. I totally agree that for those of us planning on keeping this car long term, we will need to know how to do stuff like this. I'd like to eventually have enough info and tools for transmission, transfer case, diff fluid changes, etc. I'd also like to install an oil catch can, but extra space is basically non-existent under the hood.
      06-03-2020, 06:14 PM   #13
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
Install it in the passenger side. Remove seat. LOL.
      06-04-2020, 04:20 PM   #14
DocWeatherington
Drives: F90 CP
23 Bmw M3  [10.00]
Awesome find...
      02-07-2021, 07:53 PM   #15
BmanATL
Drives: 2018 X4 M40i
Sorry, but does someone still have that procedure as the link is dead unless you pay for a single day access.
GTATX1105.00
      02-08-2021, 04:27 PM   #16
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
Dam, I should have copied all those pages. Sorry.
Here's what I recall.
The two engine ECU's (one on each side) have coolant lines going to them, and they are apparently not flexible. So you need to move these out of the way. On the passenger side the Reservoir for the coolant has to be moved out of the way, the manual I believe recommended removing it, but my tech was able to move it without removing it completely. Those are the two items that are a bit of a pain.
For the plugs, BMW strongly recommends vacuuming out the tunnel of each plug before removing a plug. Carbon deposits can end up in the engine otherwise. I did my Q7 a few weeks ago and did this, I didn't see much debris in there, but I could imagine this being a problem.
The coolant line thing is what threw me off and said this time it's on BMW. I will eventually be DIY this for next swap but hopefully someone will have a good video on it. Or I'll make a shitty video on it.
Mike
      03-09-2021, 06:56 AM   #17
BmanATL
I bought the service manual off ebay for 15 bucks. It wasn't that hard after all.
      03-09-2021, 01:07 PM   #18
AHall
Drives: 1993 Nissan 240sx
Complete service manual for $15? For the F90?
      03-09-2021, 05:45 PM   #19
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
yes, I want a copy for 15 bucks. LOL. I paid 100 for my 2015 Q7 manual.
Mike
      04-19-2021, 03:21 PM   #20
AHall
Mike
Well where is the service manual?
      04-19-2021, 04:22 PM   #21
Aronis
Aronis's Avatar
2274
Drives: 2018 M5
You are asking the wrong guy......BmanATL found one. I was waiting for him to scan the entire thing a create a PDF to share with all of us for Free. As a good deed for the day.
Mike
      09-04-2021, 12:37 PM   #22
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
No one? I bought the plugs and plan to change them soon. Don’t have a TIS subscription.
m5post
