06-14-2020, 08:12 AM | #1 |
Rep 1,077
No start stop button in M440i
So. No possibility to turn auto stop off anymore?
Not only do thy make us lag around more weight. Now its an inconvenience and a change to the way we drive Start stop is the worst thing you can do for the engine longevity Whats next? M3 will coast on track with engine shut off? |
06-14-2020, 08:36 AM | #2 | |
Rep 36
Maxdog49.00 |
06-14-2020, 09:18 AM | #3 | |
Rep 360
How is start stop an inconvenience? How does it change the way you drive? Keep in mind, they use a crankshaft mounted integrated starter, so the engine is turned on instantly, no lag at all compared to the normal start stop systems of the last generation. There is no reason to keep the engine running if you are not using it anyway, so it does not change the way you drive. It is also no inconvenience, because the engine starts when the car in the front moves, as well as soon as you lift your foot from the brake. Since it instantly turns on back again, before you can even move your foot from the break to the accelerator, the engine is running already.
In summary I would say the only downside is the increased weight. It does offer more advantages though, mainly reduced fuel consumption (about 15%, that's quite a lot) and torque boost (significantly reduces turbo lag). Edit: Here is a video of the E53 (wasn't able to find one from BMW quickly, since they just introduced the mild hybrids), that also uses a camshaft mounted integrated starter generator. As you can see, you press on the button and the engine is just on isntantly. Last edited by Flamingi; 06-14-2020 at 04:51 PM.. |
Cortexiphan2097.00 ovesund83.50 A6bullet338.00 NorCalAthlete3200.00 Jostack24.00 OM3RTA394.00 enginediver64.50 M3ditate88.50 |
06-14-2020, 10:35 AM | #4 | |
Rep 1,077
In all the cars ii had - this is the first button i press to disable it constantly and never have it on. So do most of my friends and family members. That is the most hated feature in the performance car. I want to have an option to turn it off. Otherwise it will be coded off or i will buy a different car. its that simple. |
06-14-2020, 10:52 AM | #5 |
Rep 1,077
zamboni1132.00 Spacecoast163.00 |
06-14-2020, 12:13 PM | #6 | ||
Rep 661
Drives: 2014-320Xi / 2017-330Xi
I have short commutes and this engine stop is irritating. It should be again a personal decision and option. |
06-14-2020, 12:26 PM | #7 | |
Rep 1,534
Prior's: E36, E46 x2
06-14-2020, 02:15 PM | #8 | ||
Rep 315
06-14-2020, 03:14 PM | #9 |
Rep 360
06-14-2020, 03:17 PM | #10 | |
Rep 360
The new mild hybrid system is completely seemless, you will not notice it at all if the engine is turning on or off. Please keep in mind, as I said before, it is not a conventional start stop system. The mild hybrid is the important change in the equation. Just go to your dealer and request a test drive, don't judge before that. |
06-14-2020, 03:18 PM | #11 | |
Rep 360
mcjohnsonsg386.00 wtcantfw0.00 |
06-14-2020, 03:49 PM | #12 | |
Rep 360
But it has a 48V mild hybrid system, so it is in fact set up better for the start stop. |
Pauloxxi343.50 |
06-14-2020, 04:15 PM | #13 |
I want to drive a Zamboni
1132
Rep 5,559
Drives: 13 E93 M3 18 F80 M3 16 K71
MB and VW & Audi were ahead of BMW on the Mild hybrid system, BMW is just catching up with the trend. I'm glad I had an option to turn off this feature on my F80 & E93.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
06-14-2020, 04:48 PM | #14 | |||||||||
Rep 360
I wanted to address the most common points against start/stop systems. To be fair, many points are true for conventional start/stop systems with a normal starter, but most new BMWs are mild hybrids (and in just a couple months it will be all new BMWs), so those points don’t hold anymore. Just as a disclaimer, I’m not arguing for or against start/stop systems (however, I do argue pro mild hybrid), I couldn’t care less if they put it in the car or not. I also don’t care if it’s inconvenient for somebody else, I don’t know you, I don’t give a *** if it bugs you. However, what I really hate are plain false statements. And unfortunately, I did read quite a few of those in this thread, so I want to correct them.
TLDR: BMWs use a mild hybrid setup, the new ̶c̶r̶a̶n̶k̶s̶h̶a̶f̶t̶ ̶m̶o̶u̶n̶t̶e̶d̶ belt driven integrated starter generators are extremely efficient and not inconvenient on startup like older normal starters. All negative points of old systems are addressed with the mild hybrid and additionally, more horsepower and a not unneglectable amount of torque are added. Moreover, a mild hybrid can save 10-15% more fuel than a conventional car in real world tests. Edit: Mercedes uses crankshaft mounted integrated starter generators which allow for more extra power (that's why they have 22PS more compared to the 11Ps more of the BMWs), BMW uses belt driven starter generators. Doesn't change anything really though... I really didn’t like the guy in the first video, most of his claims are based on old information, presented in a very biased way and most of all factually wrong. But luckily, that makes it easier for me to disprove. The second video was much better, the guy actually did his research and acknowledges, that most problems you hear about start/stop are non-issues. He is entirely correct with his motivation of the video: conventional start/stop systems don’t give any noticeable benefit to the driver, but only for the lab tests. Quote:
In mild hybrid systems, there is a lithium battery, so that point really isn’t an issue anymore. I find this quote of the first guy very funny in this context: Quote:
In TIS, BMW writes, they use a more powerful alternator as well as a different battery, to address the higher load of the auto start stop system. Quote:
In TIS, BMW writes an adapted starter is used (This is the case for "normal" start stop systems, since BMWs mild hybrids use an BSG and they write the starter has up to 3kW compared to the 8kW of the BSG): Quote:
Guy#2 has a great summary on the issues in his video, so I will base mine on his. There are some issues, but they are mainly miniscule: There is not a problem with the battery, the engine doesn’t wear any faster, you do in fact save a same miniscule amount of fuel. The problem with a conventional start/stop is, that you, as a driver, don’t benefit from it. It literally has no real advantage, except for a lower consumption in the lab test, because there is a disproportionate amount of engine off time. But this changes when we introduce the mild hybrid setup, that'sa actually something that both guys acknowledge in their videos. It addresses all points: It has a lithium battery, which happily will start your car thousands of times (if you were not convinced that a lead acid battery can do this job as well). It has a powerful (11PS) crankshaft mounted integrated starter generator which is meant to start your engine without any effort and even help you accelerate. Because of this, the engine itself has a decreased load and less wear. The start also isn’t annoying anymore. Further, it introduces some benefits, e.g. allowing the engine to turn off completely while driving, in turn saving fuel. It has a high amount of torque from 0 rpm, since it’s basically an electric motor, which helps you to accelerate even faster and mitigates the turbo lag. You’re also doing something about the environment, if you care about that. If we assume the start is not noticeable at all and almost instant (I can only tell you that it is, just request a test drive at your dealer if you want to see it for yourself), the only downside I can see is, that it is another thing that can break. Let me know if you can think of any other downsides. In total: BMWs use a mild hybrid setup, the new belt driven integrated starter generators are extremely efficient and not inconvenient on startup like older normal starters. All negative points of old systems are addressed with the mild hybrid and additionally, more horsepower and a not unneglectable amount of torque are added. Moreover, a mild hybrid can save 10-15% more fuel than a conventional car in real world tests. Edit: I will add sources to my statements bit by bit, if I find time for it. Most things should generally be true even without sources though (if you want to belive me). Last edited by Flamingi; 06-15-2020 at 11:28 AM.. |
06-14-2020, 07:51 PM | #15 |
Rep 92
BMW has had mild hybrids for a while as well (and full on plug ins). In Portugal we even have a 316d and 320d with mild hybrid tech (and now the m340d)
06-14-2020, 07:58 PM | #16 |
1132
Rep 5,559
The only advantage on the mild hybrid system is increased torque and limit turbo lag on engine.
06-14-2020, 08:00 PM | #17 |
1132
Rep 5,559
These models are only for Europe not available in U.S.
Spacecoast163.00 |
06-15-2020, 12:32 AM | #18 |
Rep 170
I would only watch youtube videos from Scotty as entertainment and not as education. What he says is, in my opinion, based on beliefs and not facts.
06-15-2020, 05:48 AM | #19 |
Rep 381
Wait what?? Am I reading this right the option to turn off Auto Start/Stop is removed?? Good lord I've been turning it off everyday since I got my F30, it's literally become muscle memory... wow I'm glad I didn't wait for the 4 series and just got the G20 3 series..
06-15-2020, 06:56 AM | #20 |
Rep 322
Is everyone reading Flamingi's excellent info? Up to now I have always disabled start/stop via coding.
However, if it is seemless with the new 48v system, I am willing to give it a chance. |
enginediver64.50 |
06-15-2020, 07:25 AM | #21 |
Rep 315
Yes, I read it all and it's very informative. Problem is, I have never been concerned about the wear and tear issues that Flamingi addresses...I know they aren't really a concern. It is only the annoyance/irritation factor that has made me dislike auto stop-start. It is not just about the fact that you can feel it working, but also about the fact that it makes me feel that the car is in control, not me, at moments when I want control the most,I.e. pulling out into traffic, etc. That might not be completely logical, but it's a bigger factor for me than the vibration, and I can't see it going away with a hybrid system that makes it all work more seamlessly. Having said that, I guess if BMW is taking away the ability to switch it off, then other manufacturers will follow suit and it will become the norm, so I will have to suck it up!
06-15-2020, 07:39 AM | #22 |
Rep 661
Flamingi, are you BMW employee, or supplier for BMW powertrain, or working with electric powertrain related to any automotive company?
Your knowledge goes beyond normal Joe and the level of details you explored are not described on any BMW website. |
