10-04-2020, 11:32 AM | #1 |
Rep 4,676
Alcon rotors for 2NH
FYI, Alcon is willing to create a bmw hat to fit there 400mm and 380mm rotor options that would fit the 2NH option. I'm inquiring about what a full set of rotors would cost and if partially or fully floating. Since I'm sticking with steel I Would be looking for saving a few extra pounds if possible. My googling suggests about 6lb lighter on front and 3lbs on rear. Never going to be CCB savings, but every bit helps.
10-04-2020, 01:03 PM | #2 |
Rep 4,676
Anyone have the hat dimensions that would be necessary? I'm guessing they would need lug pattern dimension and hat depth to appropriately position rotor in stock caliper.
10-04-2020, 04:56 PM | #3 | |
Rep 433
Please keep us posted on any developments |
10-04-2020, 04:59 PM | #4 | |
Rep 433
The lug pattern is 5x120mm The thread pitch is M14x1.25mm The center bore is 72.56mm |
10-04-2020, 05:59 PM | #6 |
Rep 4,676
Any chance you can grab me a higher resolution image? I'm sure this is the type of data they are after. I told them they already make a hat for the m2 CS racing, but unsure if it's the stock position since that also use an aftermarket front caliper.
10-05-2020, 12:41 PM | #9 |
Rep 4,676
Alternately
https://www.girodisc.com/Girodisc-Fr...rs_p_6855.html I'm sure they can put together some rears.
