11-10-2020, 10:27 PM | #1 |
Rep 42
M2cs winter driving
Good snowfall today
The m2cs with proper winter tires made winter driving enjoyable not stressful. The rear drive differential doing its magic was great. Front splitter or snow plow? |
10
Hedoniste3834.00 cncmastr1590.00 Bimmed Out1908.50 Supadice1027.50 Tornado1M1211.00 MadBimmeRad7121.50 6speed_M23633.50 pizza240800.50 kristobias293.50 tunawi7cheese219.00 |
11-11-2020, 02:20 AM | #2 |
Rep 1,407
11-11-2020, 05:14 AM | #3 |
Antonito
20
Rep 40
11-15-2020, 10:56 AM | #5 |
Rep 1,407
Do you think it would be a good idea to install M 437's as a winter set?
There is so little space between the front of the caliper and the inside of the rim. |
11-15-2020, 11:41 AM | #6 |
Rep 312
11-15-2020, 12:00 PM | #8 | |
Rep 658
The 437 fit absolutely fine. Same size as 763s. And the are not heavy as opposed to 788s. 763: front: 9.4 kg; rear: 9.9 kg 437: front: 10 kg; rear: 10.7 kg 788: front: 11.2 kg; rear: 11.9 kg P.S. I have been running 245+265 michelin pilot alpin 4 for two winters already and they proved to be fantastic. I have 2NH brakes and had no issues with anything stuck between calipers and the rims. And I drove a lot across the entire Europe from Portugal to Ukraine and from North of Germany to the South of Greece. Last edited by kart driver; 11-15-2020 at 12:05 PM.. |
QM287.00 |
11-15-2020, 12:50 PM | #9 | |
Rep 1,407
11-15-2020, 01:05 PM | #10 | ||
Rep 312
MadBimmeRad7121.50 |
11-15-2020, 01:29 PM | #12 | |
Rep 1,407
I measure 1cm. Last edited by Pol; 11-15-2020 at 01:58 PM.. |
QM287.00 MadBimmeRad7121.50 |
11-15-2020, 01:29 PM | #13 | |
Rep 281
11-15-2020, 01:36 PM | #14 |
Rep 1,407
11-15-2020, 01:46 PM | #15 | |
Rep 1,407
I had these on the OG M2 withe the 640's. But now I bought this set for an interesting price second hand with continental wintercontact on for the CS. Front 245-35/19 rear 265-35/19. |
11-15-2020, 01:47 PM | #16 |
Rep 658
11-15-2020, 01:56 PM | #17 | |
Rep 658
Trust me there is no need to worry. Those will work just fine. Last edited by kart driver; 11-15-2020 at 02:12 PM.. |
11-15-2020, 03:22 PM | #18 |
Rep 17
I just installed a set of 641s with 235 Alpin 4s today as recommended by BMW.
Took it for a test drive and the front right had a shallow scrape all the way around the inside of the wheel. I pulled the wheel and could not see any where on the caliper where it could have been scraping. It wasn't any part of the red caliper as there was no red paint transfer. I re-seated it this evening. Hoping I just didn't have it on the hub flush. We'll see after my drive to work in the morning. All the other wheels were fine. And the wheel with the issue spun freely when installed. Any thoughts? |
11-15-2020, 04:46 PM | #20 |
Rep 2,819
Drives: e82 1M, f87 M2cs
^^This. I must have had a stone between a front caliper and one of my track wheels last spring. I didn't see the circumferential marring on the back of the wheel until I was cleaning them after the track day. I was able to find the small mark on the caliper where the stone had lodged. If you carefully inspect the bottom of the caliper, you may also find yours.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
11-17-2020, 09:52 PM | #22 | |
Rep 312
