BMW M3 and M4 - The Icons
home
Classifieds Sponsors Classifieds Engine / Drivetrain / Exhaust / Bolt-ons
      09-29-2021, 09:55 AM   #1
Mike@N54Tuning.com
BimmerPost Supporting Vendor
Drives: 2007 335i, 2015 M3
G Chassis BMW - Burger Motorsports Wheel Spacers W/10 Bolts @ www.n54tuning.com
ORDER LINK
https://www.n54tuning.com/g-chassis-...rs-by-bms.html
BMW Wheel Spacers
Simple, Bolt-On Handling And Looks For Your BMW
Wider Stance = Better Handling & More Aggressive Looks
Best BMW wheel spacers 5x120 wheel spacers 10mm 13mm 15mm 2021 G80 M3 G92 M4 wheel spacers
BMW wheel spacers by Burger Motorsports are an excellent, cost-effective way to improve handling while dramatically enhancing the look of your BMW. Our wheel spacers push your rims and tires outward for an instant "fat" aggressive look, better lateral stability, and handling. Spacers are also great for filling in the wheel well, creating clearance for aftermarket suspension, different wheel offsets, big brakes, making your winter tires not look so inset or just making your BMW look awesome. BMS spacers are specifically designed and manufactured by Burger Motorsports for your BMW ensuring a perfect vibration free fit. Comes with a packet of anti-seize grease to place on the factory hub to aid in later removal.
Build & Quality: Each Burger Motorsports wheel spacer is CNC machined from high grade 7075-T6 aluminum alloy and anodized black for protection. Our BMW Wheel Spacers are sold in pairs (2pcs) with 10 extended lug bolts that exceed OE standards. To do the whole car you will need 2 spacer kits. All Burger Motorsports wheel spacers are hub-centric. They are safe to use on iX (all-wheel drive) BMW vehicles.
Hub-Centric: This means our spacers center bore matches your factory BMW hub and the factory-like hub on the Burger Motorsports spacers matches the center bore in your wheel for a vibration-free fit.
What width wheel spacer should I get?
Most G Chassis BMW vehicles with factory wheels and tire sizes take 10mm to 13mm in the front and 13mm to 15mm in the rear.
The photos and guidelines on this website are for reference only. Your BMW might have different results with the same size spacers due to different wheels, tire sizes, packages, and offsets.
Installation: Simply remove wheel, place spacer on the hub and bolt the wheel back up with the supplied longer lug bolts. Download the install guide.
FREE Wheel Pin tool with purchase of 2 pairs of wheel spacers on the same receipt.
To get the free wheel pin with a 2 pair wheel spacer purchase, add 2 pairs of wheel spacers to your cart, go to the link below and add the free wheel pin to the cart. When you hit the checkout button the items will be discounted to FREE!
BMW Applications
G chassis BMW only Except for F chassis M5, M8, X2, and X1 (see below)
3 Series G20 2019 - Present 318d, 320d, 320dX, 320i, 320iX, 325i, 330d, 330dX, 330e, 330i, 330iX, M340i, M340iX, including 2021+ G80 M3
4 Series G82 2021 - Present M4 and all G32 G33 4 Series models
5 Series G30 / G31 2017- Present 518d, 520d, 520dX, 520i, 525d. 530d, 530dX, 530e, 530eX, 530i, 530iX, 540dX, 540i, 540iX, M550dX, M550iX
M5 F90 2018+ M5 and M5 Competition
7 Series G11 / G12 2016- Present 730d, 730dX, 730i, 740i, 745e, 750dX, 750iX
8 Series G14 / G15 2018 - Present 840dX. 840i, 840iX, M850iX
M8 F91 F92 F93 M8 and M8 Competition
X3 G01 and X3M and X3M comp F97 2018 - Present
X4 G02 2018 - Present X4M and X4M comp F98 2018 - Present
X5 G05 2019 - Present
X6 G06 2019 - Present
X7 G07 2019 - Present
Z4 G29 2019 - Present
F Chassis vehicles please note:
2018+ F90 BMW M5 takes G chassis spacers
2020+ F91 F92 F93 BMW M8 takes G chassis spacers
2016+ F48/F49 X1 takes G chassis spacers
2017+ F39 X2 BMW takes G chassis spacers
G Chassis BMW Wheel Spacer Specifications
Center Bore: 66.6 mm
Bolt Thread Size: M14 x 1.25
Bolt Seat: Cone Seat / Concentric
Bolt pattern: 5x112 wheel spacers
Wheel Fasteners: Extended 10.9 grade zinc coated lug bolts
Spacer Material: Lightweight Anodized Black 7075-T6 Aluminum
      10-07-2021, 10:29 AM   #2
Mike@N54Tuning.com
Bump for a Great Deal @ www.n54tuning.com
and as always the LOWEST price Guaranteed!!
Mike
      10-25-2021, 09:01 AM   #3
Mike@N54Tuning.com
Bump for a great deal @ www.n54tuning.com
Lowest Prices on the FORUMS!!
Mike
      11-01-2021, 11:00 AM   #4
Mike@N54Tuning.com
Mike
      11-16-2021, 11:58 AM   #5
Mike@N54Tuning.com
Mike
      12-01-2021, 12:38 PM   #6
Mike@N54Tuning.com
Mike
      12-17-2021, 01:27 PM   #7
Mike@N54Tuning.com
Mike
      01-10-2022, 01:07 PM   #8
Mike@N54Tuning.com
Mike
      01-18-2022, 05:08 PM   #9
Mike@N54Tuning.com
Mike
      01-26-2022, 02:08 PM   #10
Mike@N54Tuning.com
Mike
      02-07-2022, 01:26 PM   #11
Mike@N54Tuning.com
Mike
      02-18-2022, 11:18 AM   #12
Mike@N54Tuning.com
Mike
      03-14-2022, 08:48 PM   #13
Mike@N54Tuning.com
Mike
      03-26-2022, 09:08 AM   #14
Mike@N54Tuning.com
Mike
      04-19-2022, 11:46 AM   #15
Mike@N54Tuning.com
Mike
      04-25-2022, 09:07 PM   #16
Mike@N54Tuning.com
Mike
      04-29-2022, 07:54 AM   #17
Mike@N54Tuning.com
Mike
      04-29-2022, 09:20 AM   #18
Doruk
Drives: 2013 528XI
Is there no 18 or 20mm versions for burger?
I sow some people go 15/20 setup. is it too much ?
      04-29-2022, 11:32 AM   #19
Mike@N54Tuning.com
These only come in 10/13/15mm currently.. You may have seen other sizes on the F80
Mike
      05-10-2022, 03:11 PM   #20
Mike@N54Tuning.com
Mike
      05-17-2022, 09:28 PM   #21
Mike@N54Tuning.com
Mike
      05-23-2022, 05:09 PM   #22
Mike@N54Tuning.com
Mike
g80
