bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Technical Topics (G42) Wheels / Tires
      05-22-2022, 05:14 AM   #1
earthie1
Drives: bmw m240i
The car I bought have the all season run-flat tires set up which is optioned by the dealer (I have no clue why they would even choose this option). I would love to get this replace. I have a few questions:
Would changing the rim/tires to an after market one void any bmw new vehicle warranty?
If I want to have a staggered set up, how would you recommend in doing so?
What tire or rim should I be getting?
Should I go to a dealer or tire shop to make tire/rim changes?
Do I need to report to my insurance company about any changes?
      05-23-2022, 09:57 PM   #2
shaman420
Drives: 22 M240i
NO
you just choose what size you want to switch. lots of threads with this info already
whatever tire and rim you like choose
Michelin pilot sport 4 or something comparable
you can go any place you trust
NO
polakai46.50
      05-25-2022, 09:13 AM   #3
N240i
N240i's Avatar
173
Drives: BMW M240i
  [0.00]
Relatively same answers as Shaman420, but anyway..
- No, Warranty can't be voided for tire/wheel change.
- BMW already gives these cars a staggered set-up with the MPro Sport Package - 255 in the rear and 245 in the front. So OEM wise, you know you can upgrade to that already. I've seen people running 265's in the back though, definitely check the different threads for a better idea.
- Rim, that's completely up to you.
- Tire - If you can, go for the Michelin PS4S', best performance street tire imo.
- Would probably be cheaper to go to a tire shop. Also you'll most likely have more options for rims at a shop vs your dealer.
- Definitely not
Make sure to post your new setup when you have it, we'd all love to see!!
      06-21-2022, 04:12 PM   #4
Ezio
Ezio's Avatar
Drives: 2023 Alfa Romeo, 2023 m240i
Aftermarket rims and tires can absolutely cause warranty problems. But its a complex question. Its all depends on what part you need repaired and how aggressive is your setup.
Always plan on keeping your stock set incase they give you problems.
KJ10496.00
      06-21-2022, 04:32 PM   #5
danallxt
danallxt's Avatar
Drives: 2022 M240x, 2007 Honda VFR
if you keep the same size as any of the factory option combinations available you should be totally ok. no way in any shape or form would that result in a warranty problem....of course if the aftermarket wheel fell apart...that's on you.
g87
