09-30-2022, 05:00 PM | #1 |
Rep 33
18x8 Offset fit
Does anyone know if a wheel with 18x8 wheel with 45mm offset will fit? I don't have the cooling package. Looks like the stock offset is 27mm which worries me. Thanks.
09-30-2022, 06:26 PM | #2 |
Rep 33
Hmmm actually may be fine.
https://www.willtheyfit.com/index.ph...h=8&offset2=45 Using the 19x9.5, 255/35 40 offset as a reference (rears on performance tires), it seems like there should be no problems. I don't see a reason why going square on the rear size would cause issues either. Is there anything I'm missing? |
10-28-2022, 01:10 PM | #4 |
Rep 187
Might need a 15MM spacer up front, rear should be OK.
These wheels would be pretty inset in the front, OEM rears are 40 offset, so wouldn't be too odd there. Wouldn't hurt to get a set of spacers all around to make sure these ones fit. Brake clearance is likely not to be an issue without the cooling pack. Currently running 18X8 et 25, no issues near brakes.
https://www.instagram.com/g87_smurf/
@g87_smurf |
