03-09-2023, 02:43 PM | #1 |
Rep 192
Widest tires on stock wheel front and rear? (no fender flares)
What are the widest tires I can fit on the front and rear with the base fenders (not fender flares from high performance and cooling package) on the stock/base wheels (not from the high performance and cooling package)
04-02-2023, 10:11 AM | #2 |
Rep 401
Drives: G42,570GT,Lp5704STS,F36,F34
Garage List 2023 BMW m240i [10.00]
17 Mclaren 570GT [9.50] 12 Lambo Supertrofe ... [0.00] 04 Lambo Gallardo ( ... [0.00] 08 Aston Martin Van ... [0.00] |
To keep within xdrive specs. No flares. None ZTK.
Tires F 245/40R19 R 275/35R19 Wheels Front 19x8.5 +25 5x112 66.6 Satin Bronze Rear 19x9.5 +33 5x112 66.6 Satin Bronze I just don't remember if I had to put 10mm spacer on front to make flush. Last edited by Saturns; 04-02-2023 at 10:49 AM.. |
hyperpip21.00 |
04-02-2023, 10:41 AM | #3 |
Rep 8
This is soooo clutch! Almost identical wheels specs to what I’ve been looking at! Stock ride height?
04-02-2023, 10:43 AM | #4 | |
Rep 401
Wheels.... https://www.superspeedwheels.com/flowform-rf05rr |
04-13-2023, 12:38 PM | #5 |
Rep 137
The Non-ZTK wheels aren't 9.5" wide though, so fitting a 275 might not be optimal.
05-19-2023, 09:33 AM | #6 | |
Rep 215
Here are the tire fittings per wheel width https://www.tiresandco.ca/tire-equivalence-advice.html . Last edited by rockblock; 05-19-2023 at 09:44 AM.. |
05-20-2023, 07:15 AM | #7 |
Rep 102
Stock wheels no fender flare are a 19x8 if you got the one that came with a square set up and 225 run flat tire. Generally if the wheel is about 85% or more of the tire width it looks okay. Start going wider than you get bulging sidewalls and it looks off.
8x25.4mm = 203mm/225 = 90% You could get away with 235 tires on stock wheels, 245s even but the look would be a little off. |
05-22-2023, 09:21 AM | #8 | |
Rep 137
The 893 wheels ARE the ZTK wheels. |
05-23-2023, 02:43 PM | #11 |
Rep 215
Maybe in the US - here in Canada they don't offer ZTK...I think here it's called "M Enhanced Track package" - it's an extra $3,500 CAD and provides Adaptive suspension + 893 wheels (all of which you can configure separately)
07-27-2023, 11:09 AM | #12 |
Rep 291
M Enhanced Track Package:
19" M Lt/Aly Wheels, Double-Spoke, 893M, Jet Black, Burnished,Perf. Non-RFT Adaptive M Suspension M Technology Package M Technology Package: With the M Technology Pack the increased heat capacity of the braking and cooling systems guarantee a long-lasting high performance under extreme driving conditions (similar to motorsport) (especially in conjunction with high outside temperatures). Includes upgrades for the drive train cooling system and the M Sport brakes. |
