06-04-2023, 07:29 PM | #1 |
Rep 125
Stud Conversion - G42 M240i
Does anyone know where I can get a set of studs to convert a G42? All the ones I see either don't look right, or are just bolts.
2023 BMW M240i - Lady Neith
Gone but not forgotten: 2021 MINI JCW GP • 2016 MINI JCW • 2012 MINI Couper S • 2010 MINI Cooper S Camden Edition |
06-05-2023, 12:31 AM | #2 |
Rep 11
06-05-2023, 08:48 AM | #4 |
60-130 Enthusiast
1397
Rep 739
I ran the Macht Schnell 75mm stud conversion kit on my car. Worked great with the 10mm Dinan spacers I had before I switched to Apex VS5RS wheels.
Just a note, I took them off the car. Studs are great, but if you have anyone with a pneumatic impact anywhere near your wheels, I would advise against using studs. I had to remove mine because the idiots at the tire shop completely destroyed them with the impact gun. The studs were coming out with the nuts. There are specific torque values and an impact gun completely negates all of that. I'd like to run studs again, but to spent $200 for another set just to have them get destroyed by some careless idiot with an impact gun doesn't appeal to me. |
06-05-2023, 08:50 AM | #5 | |
60-130 Enthusiast
1397
Rep 739
A stud conversion replaces those bolts with threaded studs. You screw the threaded stud into the holes on the hub, then you put your wheel into the studs, then screw it down with lug nuts. It makes taking the wheels off and putting them on easier and they have less risk of hitting your wheel into your rotor. They also look cool, which is why I had them. |
PRINCE THUNDERNIGHT329.50 |
06-09-2023, 02:45 PM | #6 |
Rep 2,070
If that’s the only reason, you’d be far cheaper buying a pair of stud alignment pins which, to be fair, you should have anyway
06-16-2023, 12:46 PM | #7 |
Rep 375
The motorsport studs are crap. The metal is soft and will rust quickly, the coating is a joke. I received them, many of them had damaged threads, sent them right back. These are like Harbor Freight quality. Stay with the OEM, way better.
I use the alignment pins, super easy. https://www.amazon.com/dp/B01L2WE1JK...roduct_details |
06-16-2023, 01:36 PM | #8 | |
Rep 367
06-17-2023, 04:12 PM | #9 |
Rep 2,070
