06-21-2023, 11:44 AM | #1 |
BimmerPost Supporting Vendor
4918
Rep 115,980
N54Tuning.com - Signature Werks Brake Cooling Kit For BMW BMW G8X M3/M4
ORDER LINK https://www.n54tuning.com/signature-...g8x-m3/m4.html Overview: Signature Werks Brake Cooling Kit is designed for maximum efficiency to keep your BMW G8X M3/M4 brakes cool. Our Signature Werks in-house designed 3D print air duct systems force-feed air into the 60mm hose and allow the air to flow directly to the hub and the rotor via our carefully fabricated backing plate without impedance or obstruction. Our extremely lightweight, race-quality air ducts are designed to endure the rigors of racing. It is durable and easy to manage to prevent boiling fluid and pedal fade. It can also drastically reduce pad and rotor wear and the occurrence of pad deposits or rotor warpage. Backing plates are made from 304 stainless steel with large calipers cut out area to ensure durability and fitment. Backing plates do not require hub removal to bolt directly to your front hub assembly. The 60mm width High Temp quality flex hose and hose clamps allow the car to do full lock-to-lock turns without any issues. Included in Kit: - (2) New SW in-house designed 3D print air ducts - (2) New SW in-house designed 304 stainless steel backing plates - (2) New 60mm width High Temp quality flex hose - (4) New hose clamps - (1) New hardware kit Vehicle Fitment: Model: Model: 2021-2023 BMW BMW G80/82/83 M3/M4 Notes: Slight modifications and trimming may required to the liners. |
07-04-2023, 09:32 AM | #2 |
4918
Rep 115,980
07-14-2023, 01:24 PM | #3 |
4918
Rep 115,980
07-31-2023, 11:07 AM | #4 |
4918
Rep 115,980
09-27-2023, 10:43 AM | #5 |
4918
Rep 115,980
10-17-2023, 12:00 PM | #6 |
4918
Rep 115,980
12-11-2023, 09:31 PM | #7 |
4918
Rep 115,980
01-19-2024, 01:05 PM | #8 |
4918
Rep 115,980
02-20-2024, 11:45 AM | #9 |
4918
Rep 115,980
04-11-2024, 04:27 PM | #10 |
4918
Rep 115,980
