BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > E90 LCI Sport seats into LCI e91?
Reply
      06-22-2023, 08:50 PM   #1
roblese90
roblese90's Avatar
84
Drives: BMW
2010 bmw 328i  [0.00]
Will e90 lci sport seats be plug and play with no errors in a lci e91 that came with base seats?
      06-23-2023, 10:41 AM   #2
codeterrorist
Drives: 328i
To a degree I would say since you need to get power for the bolsters/lumbar support. The seats will certainly bolt on no problem.
The plugs will connect just fine. But depending on the options like heated vs. non heated and no bolsters on the standard ones means you need to do a bit of wiring.
Don't ask me about wiring because I'm trying to get all the info I can get for retrofitting F30 sport seats into my base E90 LCI seats... fun
      06-23-2023, 12:27 PM   #3
roblese90
roblese90's Avatar
84
Drives: BMW
The seats in my e91 now are heated and powered. The seats I’ll be swapping in are also heated and powered. Only thing I’d be concerned about is will the bolsters work?
      06-26-2023, 09:00 AM   #4
codeterrorist
Drives: 328i
Yes, that's pretty much it. Take a look at the pinouts here
https://www.e90post.com/forums//showthread.php?t=480313
You can also get the same info and more using ISTA+
      06-26-2023, 10:51 AM   #5
lnxguy
Drives: 2009 335D
They'll plug right in and work without issue I'm guessing. Wiring for the bolsters is built into the seat, so if the seat gets power, the bolsters will work.
'09 335D
POBEP373.00
      06-26-2023, 09:37 PM   #6
N54MPower
Drives: Fast Cars
I swapped LCI sport seats into my E91 LCI car with base non-sport heated seats. and all of the functions including heat, bolsters, and lumbar support work with no modification.
      06-26-2023, 10:21 PM   #7
roblese90
roblese90's Avatar
84
Drives: BMW
Glad to hear, will be picking them up tomorrow
      07-02-2023, 04:20 PM   #8
roblese90
roblese90's Avatar
84
Drives: BMW
Update: seats worked perfectly with no need to splice any wires. Touched them up with an airbrush and they look brand new
Reply
