08-18-2023, 09:41 AM | #1 |
Rep 63
Radiator damaged - DIY Protection
So driving along, worst of all not even speeding, crusing at 55 in a 55, I catch presumably rock through the lower opening of the bumper, somehow bounced upward and hit the exposed portion of the radiator, bleeding coolant like a sieve.
Immediately smell the coolant and pull off the freeway and into a parking lot. Call BMW Roadside assistance and towed to my local dealership. Dealership and BMW corporate both said not covered since it’s a road hazard and I call bullshit because the radiator should have been better protected. I’m not shelling out $2,700 out of pocket nor going through insurance after 1 month of ownership of a new M2 just because they provided inadequate protection. Matt Watson (Carwow) points out in his video that this is an obvious problem. Made a big stink on social media, BMW corporate gets in contact and they take care of it. Anyway, I painted some metal masonry mesh black and installed it behind the bumper. Highly recommend it to all |
08-18-2023, 09:12 PM | #3 |
Rep 63
Albator_IIII1013.00 |
08-19-2023, 12:22 PM | #5 |
Retired Major
1013
Rep 738
Looks good. Mind doing a DIY guide for the community?
2023 G87 ///M2 (production began Jul 4th 2023) 2008 E90 335i | Silver Grey | Terra | Piano Black | 6MT | ZSP | ZKO | ZAT | ZKI | ZPL | ZKL | |
08-20-2023, 08:29 PM | #6 |
Rep 63
Supplies:
steel lath/mesh Rustoleum 2000 F high heat flat black (because it doesn’t say to not use on galvanized metal which the lath is) Procedure: Cut steel lath to size (about 22” x 6.25”) Power wash the steel lath and let dry Spray on the flat black, leave to dry When dried, flip over and spray other side. Repeatedly adjust angle of spray to get all surfaces on the steel lath. Let dry 2 hours Bend slightly as you slide it into space behind lower opening so as to avoid scratching bumper with sharp metal edges. Do not bend so much as to create a crease in the lath, should spring back to flat. Use black zip ties top and bottom around the vertical bars of the air opening to fix the metal lath in place |
Albator_IIII1013.00 baron951703.50 |
08-20-2023, 08:31 PM | #7 |
Rep 63
08-23-2023, 07:23 PM | #9 |
Rep 63
Photo below
09-10-2023, 11:01 AM | #14 | |
Rep 355
Drives: BMW G87 (2024),BMW E82(2009)-s
09-10-2023, 12:01 PM | #15 |
Rep 635
Same thing many of the C8 guys are doing. I never saw an instance yet of someone actually getting a puncture that causes a rupture. But many people posting pictures of several damaged and bent fins.
So a few companies make preformed mesh screens for the C8 bumper openings. And many people just do what you did - make their own screens |
09-11-2023, 07:56 AM | #17 |
Rep 152
Drives: Like it's a rental!
BMW is just following the lead of Porsche and other brands. Gotta give the dealer network some stuff to fix, and the aftermarket some 'upgrades' to sell.
2022 G07 M50i, 2019 G01 30i, 2017 F25 28i
A couple of other fun cars in the current stable SOLD 2013 E93, Interlagos Blue, ZCW, ZPP, 223, 2MK, 19"s, 655, 6NR, 752, 4MY SOLD 2013 E70, Carbon Black, Cinnamon Brown, M-Sport |
09-11-2023, 08:05 AM | #18 |
Rep 3,419
Not buying it. Dealers aren't going to fix for free, so they're pushing cost and upsells on customers, which is BS.
09-14-2023, 11:07 PM | #19 |
Rep 753
The same thing just happened to me. I haven't talked to management or corporate yet. Hopefully it can get taken care of. Wish me luck.
https://www.bimmerpost.com/forums/sh....php?t=2048502 Update: My dealership did a one time good-will repair for the radiator, but they will not do this again. So now I will work on finding a fix for this problem that BMW should have eliminated from the start. Last edited by Rx-7ames; 09-15-2023 at 01:32 PM.. |
M2siast5876.00 |
09-21-2023, 08:11 AM | #20 |
Rep 3,022
Drives: 2019 M2 Competition
I will be installing Zunsport screens as soon as they are available. I had them on my F87 and they were fantastic, as I even had one survive a deer strike! (wish I was kidding)
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
DSTR1241.00 |
10-25-2023, 08:29 AM | #21 |
Miker
Rep 4
Some other DIY material options
The Zunsports look really good with a nice clean install. They also have a grill to protect the under body oil cooler. Not super cheap but not unreasonable either. You would get the three lower front grills and the under body for significantly less than the underbody skidplates I had been looking at to protect the oil cooler. I found several grill materials on Amazon and ordered some samples for potential DIY. Ordered these as I will use them on another project if I don't use them here. The first two are aluminum, the last one plastic but all are sturdy enough to provide significant protection. I might go a bit smaller on the holes on the plastic one. There are a number of hole size and shape options. I will post with my final decision
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/dp/B08PBM1C2F...roduct_details https://www.amazon.com/dp/B0B28636PY...roduct_details |
rippernash69.00 Resoelg244.00 |
