BMW X5
      09-07-2023, 01:37 AM   #1
F10_User
Drives: X5
2022 bmw x5   [0.00]
2015 bmw 535i  [0.00]
Gas prices 89 octane rating min
As we all know gas prices are up the roof, do you all still put the recommended 89 min (premium) on your vehicles?
      09-07-2023, 06:34 AM   #2
Boardmember
Drives: BMW X5 xDrive40i
In my state, choices are 87, 89 and 93. 93 comes at a minimum $.70/gal premium, frequently more. Yes. Every time.
      09-07-2023, 07:38 AM   #3
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
I use Premium 93 in my 45e given I don’t refuel as much. 89 is considered Plus where I live, and I wouldn’t hesitate to fill up with it if my situation were different
      09-07-2023, 08:55 AM   #4
Gene Horr
Drives: X5 50e
In general, for modern vehicles driving in a moderate manner using a lower octane than requited does not physically hurt anything. The computer will retard the timing to prevent detonation (sometime called 'knocks and pings' because that is less scary sounding) and dieseling isn't an issue with electronic fuel injection.
But you probably aren't saving much money. The retardation lowers the fuel economy, reducing or sometimes eliminating the per gallon cost savings. And if living in a high heat climate, or really pressing on the throttle, then you are not only reducing efficiency even more you might exceed the capability of the systems to compensate.
Personally, I wouldn't unless it is cool weather and you plan on driving slow and cautious.
      09-07-2023, 08:57 AM   #5
MassWholeBimmer
Drives: 2023 X5 M50i
I put 93 in. Big $ jump from 87 to 89. Not so much from 89 to 93. So 93 it is.
Side note: My F150 requires a min of 87. I've put in 93 and never really noticed much difference. I think the 3.5 HO (Raptor f150) requires premium.
2023. X5 M50i
2019. F150 SCREW 3.5 L Ecoboost
      09-08-2023, 10:18 AM   #6
Gene Horr
Drives: X5 50e
This is normal. Lower compression engines get no benefit from higher octane fuel and a case could be made that there is a negative due to less energy/gallon.
      09-09-2023, 08:56 PM   #7
weinerbarn
Unapologetic Tool Hoarder
weinerbarn's Avatar
734
Drives: 2020 X5 M Competition
X5MC gets 93 every time but I also do not drive it much. Less than 3,000 miles per year. Other vehicles, all turbo will get 93 most times but if I'm going on a long road trip, not towing and just planning on cruising and burning fuel, then I will put mid (89) in since I know I'm not going to be in much boost and no need for higher octane. The cost savings adds up over a 1-2K mile round trip.
      09-11-2023, 07:01 AM   #8
cobramite
Drives: '24 X6 M60i, '22 Macan GTS
You then need to run down to near empty when you refill with 93 octane. Not worth it for 25 bucks.
Don't be the guy with a $150,000 911 filling up with Sam's club penny pincher mystery gas.
1Boxer34.50
BDGJ24.00
      09-12-2023, 09:12 PM   #9
weinerbarn
weinerbarn's Avatar
734
Ha ... fair point. I've actually never filled my X5MC up with anything but 93 but the other cars like 540i, I don't really care enough about to worry. But you are correct, $4 per tank isn't making car payments and if you're that tight, you probably bought the wrong vehicle.
      09-13-2023, 08:09 AM   #10
2heeldrive
2heeldrive's Avatar
57
Drives: 2019 X5 4.0, 2022 330ix
I worry about LSPI (Low Speed Pre-Ignition) which is very bad for pistons/rings/plugs etc. and is a function of octane and oil vapors. I don't think timing is much of a factor. So I run 93 octane which is the highest I can find around here.
This is pretty good explanation of LSPI:
https://www.valvolineglobal.com/en-eur/what-is-lspi/
      09-17-2023, 07:29 PM   #11
LDT
LDT's Avatar
1540
Drives: 2024 X5 M60i
93 all the time. Costco sells only top tier fuel and is always the lowest price.
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^
2017 X5 35d--still in my diesel phase
2015 GL 350--diesel burner/highway queen
2013 Audi S6--a beast in it's day
      09-18-2023, 06:20 PM   #12
christianb5s4
Drives: Built 2001 Audi S4
91 octane only on our x40i. Not worth cheaping out on fuel in my opinion, despite the cost difference.
2024 M3 CompX Dravit Grey - MP HAS - Millway - MHC+ carbon - CS software - MAD single-mid - PPF
2019 G05 X5 x40i, built 2001 600whp B5 S4.
      09-21-2023, 09:28 AM   #13
HowardThings
Drives: 2014 BMW X5 xDrive35d Msport
I use 89 frequently.. (40i)
Initially it was an accident but I took the opportunity to do some logs monitoring knock, boost, and timing corrections.
Findings: it’s barely noticeable. DME adjusted boost to build up a little later but it was perfectly fine otherwise. WOT pulls were okay as well even with IATs getting as high as 130 degrees. I get about 500 miles to the tank with easy driving. With a difference of $12.00 a tank, I only justified it since I drive about 30k miles a year with A LOT of idling in between. I just don’t see the point of it unless I’m beating on it with my jb4 set to map 3 or just take the race car out. I don’t see a problem using 89 for a commuter car.
Now this is on a completely stock car with stock tune (jb4 map 0). I would NOT recommend anyone running a tune if any sort running under 91/93 octane.
2016 BMW M5
2019 BMW X5-This will hit 10's in the 1/4 mile
      01-06-2024, 10:13 AM   #14
hyperion69
Drives: X5 G05 40i
Exactly... Cheaping out on fuel with a premium car is madness. In Europe, we pay ~ 5-6$ / gallon (octane 95/98)
xbimmers
