09-10-2023, 06:03 AM | #1 |
Rep 72
How to: code anti dazzle with BimmerUtility
Hello, thought I'd post this recipe to code anti dazzle using BimmerUtility (and esys, though you should be able to do this entirely in BimmerUtility).
1. Following this guide (https://f80.bimmerpost.com/forums/at...0&d=1438745738), VO code out option 5AP (Decoding Anti-Glare High-Beam Assistant). 2. Recode units BDC, FLM, KAFAS and MGU to factory values. 2a. Code back in whatever you had coded for these modules. 3. Code in these KAFAS values: 3100 COUNTRY_VARIATION: EUROPE_RC 3102 C_FLA_CC_MESSAGE_3: No_Cc_Message C_FLA_COUNTRY_WITH_MULTIPLE_REFLECTORS: active C_FLA_US_SENSITIVITY_MODE: Normal C_FLA_BS_ENTER_THRESH: Rest Of World C_FLA_BS_EXIT_THRESH: Rest Of World Last edited by dmr; 10-13-2023 at 12:30 PM.. |
10-07-2023, 10:02 AM | #2 |
Primo Generalissimo
4675
Rep 4,026
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
Are these the steps to keep the high beams on full time?
10-08-2023, 07:09 AM | #3 |
Rep 72
10-08-2023, 07:27 AM | #4 |
Primo Generalissimo
4675
Rep 4,026
Drives: All of them
Yes, I guess that’s what I mean. For example, my Ford Super Duty is set to high beam all the time, but light go to low beam when oncoming traffic is present. It’s obviously not as advanced as BMW so it simply turns off high beams vs shaping the beam.
10-08-2023, 10:06 AM | #5 |
Rep 3,001
Drives: A Family Sedan
What’s the difference between this and the BimmerCode steps in terms of results?
10-08-2023, 12:23 PM | #6 | |
Rep 72
With this method, I am confident that, aside from country options, ALL parameters are set properly everywhere, since you remove the "decoding of antidazzle" from the vehicle order, then reset each of the units to factory values (with antidazzle now "not disabled"). |
M2siast5918.00 |
10-13-2023, 09:43 AM | #8 |
Rep 375
I'm very interested in trying this. Do you have the link to the source where this info was from, I'd like to learn more.
Thanks Last edited by Ruebarb; 10-13-2023 at 11:04 AM.. |
10-13-2023, 12:28 PM | #9 |
Rep 72
This is the source :-)
But I gathered this from numerous threads in the g80 forum here, and other places I forget now. Note that I updated my original post to add the VO coding guide URL. |
10-16-2023, 10:13 AM | #10 |
Rep 405
Coming here from the G05 section - would love to get instructions to accomplish this using only BimmerUtility if someone can provide the code or instructions.
