BMW M3 and M4 - The Icons
home
Classifieds Sponsors Classifieds Engine / Drivetrain / Exhaust / Bolt-ons
      10-24-2023, 11:07 AM   #1
vividracing
BimmerPost Supporting Vendor
vividracing's Avatar
Drives: E90 M3, F30 335i, F80 M3
The most affordable exhaust on the market
Vivid Racing Presents: Titanium Valvetronic Catback Exhaust With 102mm Tips
TravisW@vividracing.com | +1.480.966.3040 x318 | www.vividracing.com
https://www.vividracing.com/my-deal/5ODNYFMO
With our BOOSTOBER Sale this is THE MOST AFFORDABLE EXHAUST ON THE MARKET.
Looking to maximize your performance with a Titanium exhaust that uses OEM valves, and doesn't kill the budget! This is the exhaust for you!
The VR Performance Titanium exhaust for the BMW M3 G80 and M4 G82 is the best exhaust upgrade you can do! Upon the release of the new BMW G8x, enthusiasts were on the fence about the new design. However they were not concerned with the new S58 engine. The improved engine over the S55 has incredible potential when it comes to making more power, but the exhaust system is holding you back!
VR Performance released a full titanium, valvetronic, catback exhaust system for the M3 G80 | M4 G82 to increase performance and unlock the full potential of this platform. By installing the VR Performance catback exhaust system you will significantly decrease back pressure. The 3-inch diameter permits much better flow throughout the system which will also provide exceptional power gains.
The whole exhaust only weighs 42lbs thanks to the 1.1mm thick titanium construction. This weight saving will cut down your lap times while giving the S58 much-needed flow. VR Performance takes advantage of the stock valving on the exhaust by utilizing the factory valves while still retaining the different driving modes. When the valves are closed, exhaust gases are routed through the center muffler for a calm, cool sound. But when the valves are open, the exhaust is straight through and out the beautiful 102mm titanium tips for an aggressive tone.
The valves will open or close depending on which drive mode you have selected offering an enhanced driving experience. If you are cruising through the neighborhood or starting your car without wanting to disturb anyone, retaining the valvetronic function is essential. Installation is quick and easy with no modification required.
Features:
  • Full titanium construction
  • Weighs 38lbs less than the factory stainless steel exhaust
  • Eliminates restriction thanks to the 3-inch piping diameter
  • Pie cut bends offer exceptional flow without turbulence
  • Retains factory valvetronic functions
  • Designed using 3D scanning and CAD for precision fitment
  • Weighs 42lbs for a full catback!
  • No modification required for installation
  • Does not trigger a check engine light
  • 102mm exhaust tips
Fitment:
  • BMW M3 G80 | BMW M4 G82 Chassis
Note:
  • Hardware Kit is included for O2 sensor bungs that are not used.
Sound Clips!
https://www.youtube.com/watch?v=BWQ5iZAkqdE
Travis Williams
Shop ALL BMW G80 | G82 Parts Here!
480.966.3040 ext 318 Travisw@vividracing.com
PM, Email, or Call Directly for aggressive BMW Member Pricing
Tags
catback, catback exhaust, exhaust, titanium, titanium exhaust
g80
