BMW X5
      11-25-2023, 06:28 PM   #1
johnnyace
Drives: M2C
2024 X5 M60i DIY oil change
Wow this S68 holds 10.75 liters. Was straightforward. Just be careful not to over tighten the plastic plugs.
Edit: The P/N 07145A38759 label should be shown with the oil drain plug on the left. In the pic, that label is incorrectly positioned beneath the filter housing drain plug which is included with the filter.
      11-25-2023, 08:39 PM   #2
pixelate
pixelate's Avatar
65
Drives: X5 M60i
Thanks for those photos. Looks simple. First time I've seen a plastic oil drain plug.
So I see a 36mm socket for removing the filter housing, but what's up with the drain plug in the filter housing (which uses a T-something Torx?). Does it need be removed? I could see how draining the filter housing before removing it might lessen any oil spillage when the filter housing is removed.
2024 BMW X5 M60i manhattan green
1998 Porsche Boxster arena red (race car since '11)
--previous bmws--
2008 BMW X5 xDrive48i mineral green
1972 BMW 2002 agave green
      11-25-2023, 09:20 PM   #3
johnnyace
Drives: M2C
I suspect the purpose of the filter housing drain plug is just as you mentioned - for less mess. Next time I will consider leaving it in to see for myself. Potentially one less thing to fuss with.
      11-25-2023, 11:29 PM   #4
eelnoraa
Drives: G05 X5
Plastic oil drain plug is dangerous, but more so dangerous is plastic lower oil pan that drain plug screwed into. I guess if oil pan is plastic, plug must be of material if same or lower hardness, else the thread on the pan will be gone after 2 oil changes. Plastic oil pan mean it will sure wrap and leak, just matter of when.
2022 G05 B58/PHEV
+ a few very old BMWs
      11-27-2023, 02:24 PM   #5
roamio
Drives: 24 X5 M60i
@johnnyace
Thanks for taking time and sharing with us.
      11-27-2023, 04:22 PM   #6
RidgeHauler
Drives: BMW X5 M60i
Thanks for posting this M60i oil change info. Much appreciated.
      11-28-2023, 02:52 PM   #7
roamio
Drives: 24 X5 M60i
Delete (sorry).
      12-15-2023, 08:54 AM   #8
kawamatt2
Drives: BMW X5 M60i
I just completed this job as well. Attached is a document with part numbers, tool sizes, quantities, and instructions for resetting the oil life monitor in-dash. As well, adding 10.75 liters after letting sump and filter housing drain for ~30 minutes resulted in this level reading.
xbimmers
