12-07-2023, 05:39 PM | #1 |
Rep 817
Post Break-In
Probably redundant but I have not been able to find an answer. Is it safe to push the car all out after break in? I just got it done today! I wanted to hit redline and get some heat going.
Thoughts? Had a full diff and oil replacement. |
12-07-2023, 05:46 PM | #2 |
Rep 261
Send it
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
19
Searay55555376.00 M2siast5876.00 Newgenbimmer103.50 Baller145.50 superleggera_2125.50 CadolinaRipr319.00 LCDRJohn607.50 ToneM2148.50 Vinknee88.50 Tenac4541.00 BMR.WRLD255.00 JG13224.50 two_three_two516.50 KCuv421.50 GT3M2175.50 HulkMansfield70.50 TorontoRedCoastie116.00 daddyjaxx4.50 Geighty71404.50 |
12-07-2023, 05:47 PM | #3 |
Rep 2,978
12-07-2023, 05:49 PM | #4 |
Rep 2,291
GIT ER DUN!
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
12-07-2023, 05:51 PM | #5 |
Rep 817
I love the feeedback!!!!
Bumpinjeep5532.50 |
12-07-2023, 05:55 PM | #6 |
Rep 978
Drives: 2023 X4 M40i (G02)
Yes!!! That's where all the fun start just to be mindful of the traffic, enjoy!!!
2004 Toyota Vios | 2004 BMW X3 | 2007 Chrysler Town and Country | 2007 Ford Escape | 2008 Honda CRV | 2017 Nissan Versa Note | 2017 Toyota RAV4 | 2017 Toyota Yaris iA | 2019 Porsche 911 | 2023 BMW X4 M40i
Geighty71404.50 |
12-07-2023, 08:08 PM | #10 |
Rep 817
12-07-2023, 08:24 PM | #11 |
Rep 75
Drive around for good 15min and warm it up, and then send it!!!
Geighty71404.50 Kevin_The_Clean13286.00 |
12-07-2023, 11:00 PM | #13 |
Rep 817
12-08-2023, 12:07 AM | #15 |
Rep 843
12-08-2023, 12:14 AM | #16 |
this is the way
18160
Rep 8,527
They install a flat plane crack, remove the limiter which raises the redline to 9800 RPM and they also give it 121 more hp for good measure!
12-08-2023, 06:26 AM | #17 |
Rep 2,987
Drives: A Family Sedan
12-08-2023, 06:33 AM | #18 | |
Rep 1,168
You can drive it as you wish though as others have offered the engine should be fully up to operating temperature -- watch that oil temperature to know when the engine is up to temperature -- before you hit red line. If you push the car hard after you are finished drive the car some give the engine and drive train time to shed some heat load before you put shut off the engine. More spirited driving could increase oil consumption. So after you subject the car to more spirited driving check the oil level more often. |
Ointment044053.50 Kevin_The_Clean13286.00 |
12-08-2023, 06:46 AM | #19 | |
Rep 1,168
In looking at my car's RIS service invoice I see a multi point inspection was carried out. And a "BMW standard scope service" was done as per factory warranty maintenance. Also the tech test drove the vehicle. This was mentioned on the invoice. At drop off the car's odometer was at 1204 miles. Upon getting the vehicle back the odometer was at 1207 miles. |
M_Power Rob3684.50 |
12-08-2023, 07:57 AM | #20 |
Rep 44
Time for Ricky Bobby mode. I have my break in service in 2 weeks.
12-08-2023, 08:46 AM | #22 |
Rep 2,987
