01-18-2024, 07:28 PM | #1 |
Supreme Allied Commander
3848
Rep 54,383
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
Girodisc BMW G8X M2, M3, M4 380MM FRONT ROTORS
These GiroDisc 2-piece rotors are a direct replacement for the front rotors on the G80 M3, G82/83 M4, and G87 M2 without carbon ceramic brakes. Our 2-piece, fully floating assemblies help shed unsprung weight and rotating mass from the front axle of the vehicle. The rotor rings are machined from a proprietary casting made of high-carbon steel formulated to GiroDisc’s specifications. This superior metallurgy results in a rotor that holds up better, and the 72 curved vanes act as a centrifugal pump pulling air in through the hub to effectively cool the rotors under hard use. The 2-piece design means a reusable hat which can be attached to new rings (part number D1-282) when they need to be replaced. All major components including the hats, rotor rings, and drive pins are manufactured in-house at our facility in Bellingham, WA from domestically sourced materials. The hat is made from 6061-T6 aluminum and coated in a black anodize finish. The drive pins are made from a high-strength steel alloy and cadmium-plated for corrosion resistance. All rotors are assembled with spring clips and Belleville washers for race-ready float while also being street-friendly with no noise from loose hardware. The minimum thickness at which we recommend replacing these rings is 34mm. We also recommend replacing them if a crack leads to the edge of the ring. $1300 pair https://hpautosport.com/product/bmw-...-front-rotors/ |
