bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW M2 Forums 2023+ (G87) Exterior Modifications
      03-08-2024, 05:29 PM   #1
JABCAT
Professor
JABCAT's Avatar
2255
Drives: '23 M2 & '22 X3 M Competition
AutoID gloss black CSL-style grille installed
Installed the gloss black CSL-style grille from AutoID & the black M2 grille emblem from IND. The most difficult part was getting the oem grille out and the new grille in. Removing/reinstalling the front fascia was very easy. I like this grille much better than the oem. I had the grille covered with Xpel before install.
Here's the tools needed and pics.
Jack & Jack stands
17mm socket to remove wheel bolts
10 mm socket
8 mm socket
T-30 bit
Plastic trim tool.
1. Jack up the front, place on jack stands, & remove the wheels.
2. Remove (13) 10 mm screws holding the front fender liner in place (both sides). Remove front fender liner.
3. Unplug parking sensor (both sides) & remove large wire harness passenger side only.
4. Remove (10) 10 mm screws & (8) plastic push pins from bottom of the fascia.
5. Pop hood & remove weather stripping.
6. Remove (4) plastic push pins along top edge of fascia & remove plastic trim piece.
7. Remove (10) T-30 screws along top of fascia.
8. Carefully remove front fascia.
9. Remove oem grille from inside front fascia. I used the plastic trim tool to lift up on the black tab at each slot and my other hand to press down on the red tabs. I wasn't pulling with enough force initially for fear of breaking the tabs. Finally, out of frustration, I started using more force and was able to work each tab out.
10. Install new grilles over the tabs in the fascia. The fitment of the AutoID grille could be a little better. The slots that the tabs need to go through were a little too narrow, so it took a good bit of force to get the grilles seated correctly.
11. Re-install front fascia.
12. Admire your new grille.
Her's: '22 X3 M Competition, Marina Bay Blue, Tartufo interior, 21" 892M wheels, executive pkg, carbon fiber trim.
His: '23 M2, Toronto Red Metallic, M highlight interior, carbon fiber interior trim, shadowline, lighting pkg, auto cruise, live cockpit pro.
M2Jorge785.00
JCoR126.00
M2GTI103.50
apez649.50
xtougher560.00
      03-08-2024, 07:37 PM   #2
JCoR
JCoR's Avatar
126
Drives: 24 M2, 21 Silverado
2024 M2  [10.00]
Those are sexy. I think I'm going to have to order a set.
g87
