Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - How to Disable e92 “ Seatbelt Assist ” arm
Reply
      09-25-2006, 01:19 AM   #1
.psd
.psd's Avatar
Drives: 328i/Silver/Sport PKG/Prem PKG
A) For those who don’t like to read directions: Take out the seatbelt fuse
B) For others who want a detailed directions, read below:
FIRST:
Do this in the daytime for more light.
Press in the key (do not press Start Button) - radio should come on, AND Seatbelt Assist.
1) Open the glove box and get out the flashlight. Take notice of both knobs at the end of the glove box. This is the fuse box.
2) Twist both knobs 90 degrees
3) Take the small paper diagram of the fuses out.
4) Look for the seatbelt icon with the number 25 beside it
5) Turn the small paper diagram over to the fuse map and find the location of ‘Fuse 25’
6) Take the fuse installer out and find the 10amp fuse in spot 25
7) Take the fuse out and store it in a safe place if you need to replace it.
8) Put the fuse installer back in the fuse box and close the fuse box cover. Make sure the twist knobs line up before closing the glove box.
Last:
Press in the key - radio should shut off.
Press in the key - radio should come on, but NO Seatbelt Assist.
Important Notes:
A) I took the car out and DID NOT put on the seatbelt, the chime for the seatbelt still comes on.
B) I am not 100% certian if this effects the airbags. I know that some cars passenger airbags will not come on if there is no one in the seat at the time of impact. Due to taking out the fuse, this might deactivate the sensor in the seat, but I am not sure... with that said, use at your own risk.
      09-25-2006, 03:52 AM   #2
PresaMat
PresaMat's Avatar
Drives: 67 GT500,69 Boss 429, 335i
Thumbs up
Great Post!!! Thanks very much - they look so fimsy I can't wait to get my car just to disable them! Thanks again.
Mat
      09-25-2006, 04:02 AM   #3
ZuerstBMW
‘Viva Espaρa!
ZuerstBMW's Avatar
373
Drives: 2023 230i Mineral White
And they look cheap.
23 G42 230i Mineral White Cognac, Aluminum With Mesh Effect Interior Trim MODS Clear Guard, 15% Ceramic Tint, Floating Caps
      09-25-2006, 06:33 AM   #4
kapoo
kapoo's Avatar
126
Drives: 2023 Chevrolet Corvette C8
2009 Subaru WRX STi  [0.00]
2009 Scion tc  [0.00]
2007 335i  [0.00]
Wow! Thnx for the help!! i know u saved alot of people from having to repair that in the future..
      09-25-2006, 07:07 AM   #5
RichP
RichP's Avatar
Drives: F80
Nice, I need to go pull the fuse on my headlight washers, unless its winter, they make more mess than they clean.
      09-25-2006, 07:51 AM   #6
jhalbri
jhalbri's Avatar
Drives: 2002 330ci to 2007 328xi
Thanks .psd for the detailed info on disabling the seatbelt butler. Great info for everybody.
      09-25-2006, 07:58 AM   #7
Kenny C
Drives: 2007 335 e90 1998 e39 540
2023 BMW i4 m50  [0.00]
2020 BMW M340  [0.00]
2018 mx3 40  [0.00]
2016 340  [0.00]
2013 BMW ACYIVE HYB ...  [0.00]
2010 BMW X535D  [0.00]
Before I did that I would find out if taking out the fuse disables the airbag. Who knows if you KILL your passenger what YOUR consequences may be. Accidents happen and technology is there to help us out but you will have to live with yourself not to mention possible legal problems.
      09-25-2006, 08:36 AM   #8
picus
picus's Avatar
Drives: e92 SG 335i Coupe
Sticky imo; great post.
      09-25-2006, 08:42 AM   #9
3thirty5
3thirty5's Avatar
Drives: 2014 BMW M5
2014 BMW M5  [0.00]
thanks for the great info! The seatbelt assist actually doesn't bother me that much... but when it does i'll know what to do!
      09-25-2006, 08:45 AM   #10
MrSilver
Judge Advocate General
MrSilver's Avatar
Drives: e92 335i
2007 e92 335i  [0.00]
Thank you for your great post!!!!!
'07 E92 335i "Over-Heating" and "Blowing Up" since 9-5-06
6MT, Space Gray, Gray w/ Dakota Leather, Dark Burl, ZSP, ZPP, ZCW
Comfort Access, Sirius Satellite (Howard is not optional)
'07 X3 3.0si - Black on Black, ZPP, ZCW, Step. - Wife's car
      09-25-2006, 08:56 AM   #11
Ninjaneer
Shadow Warrior
Ninjaneer's Avatar
Drives: '07 335i Sedan
Was thinking the same thing. Everyone seems so eager to disable it and neglected the airbag comment
Great post though
335i E90 / Arctic / Gray / Burl Walnut / Steptronic / ZPP / ZSP / Paddles / CA / Nav / PDC / OEM Spoiler
Mods:
PIAA Angel Eyes, Rear Fog Switch, Escort X50 Blue hardwire, 30% Charcoal Llumar
Installing soon: Rear Power Outlets (Happy Robot mod!)
      09-25-2006, 09:05 AM   #12
PiperD
Clutch pedal >> Dead pedal
Drives: '11 e92 335is 6MT
May also want to look into the seatbelt pretensioner as well - is that disabled if the fuse is out?
My hunch is that the airbag system would not be affected, since I believe the system looks for a certain amount of electrical resistance from each airbag, and alerts you if there's a problem. That was my experience from my '00 328, which had to have an airbag replaced. OBC kept generating fault codes because it wasn't detecting the driver airbag properly.
But that's just a hunch - I agree that I'd prefer to have a concrete answer as to what fuse 25 really does!
Still a good find by the OP tho
In my garage: '11 e92 335is 6MT (05/10) SpGrey/CoralRed/GlacSlvr ExecPkg/NavPkg/19" 225M
Retired: '07 e92 335i 6MT (12/06) SpklgGrpht/CoralRed/GreyPoplar
Retired: '04 330Ci M-Sport 6MT SilverGrey/NaturalTan/MyrtleWood
Retired: '00 328Ci 5MT SteelGrey/Grey/MyrtleWood
Retired: '87 Pontiac Grand-Am 3AT White/Grey
      09-25-2006, 09:55 AM   #13
.psd
.psd's Avatar
When I took Fuse 25 out, I drove around the block and noticed that the seatbelt chime came on (because I wasn't wearing my seatbelt), So it definitely detected me (without giving me the belt). Therefore the proper airbags should work because the seat knows there's a person in it.
      09-25-2006, 10:03 AM   #14
RodyP
RodyP's Avatar
Netherlands
61
Drives: 19 Bmw M5 Competition
this doesn't shut down the chime ?
      09-25-2006, 10:09 AM   #15
.psd
.psd's Avatar
No, the chime is STILL active.
      09-25-2006, 10:10 AM   #16
RodyP
RodyP's Avatar
Netherlands
61
isn't there a fuse to get the chime out
      09-25-2006, 11:15 AM   #17
.psd
.psd's Avatar
Not sure about the chime fuse.
      09-25-2006, 11:26 AM   #18
zamboni
I want to drive a Zamboni
zamboni's Avatar
Drives: 13 E93 M3 18 F80 M3 16 K71
16 K71 F800GT  [10.00]
2018 F80 M3  [10.00]
2013 BMW E93 M3  [10.00]
This mod is crazy and unsafe.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue
13 E93 M3 Melbourne Red
2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3
My next vehicle would be a Zamboni
      09-25-2006, 11:50 AM   #19
KUweatherman
KUweatherman's Avatar
United Kingdom
Drives: Civic Si
No, putting on your seatbelt does that...
      09-25-2006, 11:57 AM   #20
RodyP
RodyP's Avatar
Netherlands
61
we all know that, but if you drive every time for like 5 min it gets irritating
      09-25-2006, 12:11 PM   #21
Pedal2Floor
Pedal2Floor's Avatar
Drives: 335i Euro Delivery Fall 2008
I doubt that Fuse 25 does anything except handle the butler. If the butler is broken or damaged in such a way that caused the fuse to blow it would then disable other safety system - that seems pretty stupid plus NHSTA would not be too happy about that. Also, because the butler give you the belt does not mean it know you put it on which makes no sense for the safety systems.
I assume there is another system under the seat for the air bag as required by new regs and that the seat belt clicker has another sensor and the belt butler is completely out of the safety loop.
The fact that chime still plays tells me that safety systems have detected that you do not have your seat belt on.
I don't believe pulling the fuse will cause a problem. The only problem that remains is covering up the arm so that nobody tries to pull it out but hand like a toy and breaks it.
Truely, the belt butler is a piss poor feature and hope it goes away in MY08.
      09-25-2006, 01:14 PM   #22
.psd
.psd's Avatar
/\ You are totally right.
Fuse 25 only works the electrical mech for the seatbelt assist. Nothing more.
It's just like taking out a rear wiper fuse, sunroof fuse or power window fuse. When there is no fuse, the specific part simply does not work.
Reply
