BMW 3-Series (E90 E92) Forum
DIY - E90 Xenon lights retrofit (official BMW instructions)
09-29-2006, 04:25 PM | #1 |
Administrator
40932
Rep 21,240
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
12-09-2007, 10:09 AM | #6 |
Rep 2,385
PM Jason, he prolly still has it. I may have it on another computer still but won't be able to look till tomorrow.
retired 06 E90 325i New: 09 VW Platinum Grey Jetta Sportwagen 2.0T SEL w/DSG, panoramic sunroof and Ipod adapter |
12-09-2007, 10:40 AM | #8 |
Rep 2,458
04-04-2008, 12:23 PM | #13 |
Rep 1,241
Drives: 2016 BMW 340i
Yep, the first link does not work!
09-30-2009, 12:34 PM | #15 |
Rep 26
Guys cant i directly place the original xenon headlights on my e90 and tap with the on board computer?
because where i live its much simpler than that no wiring kits is needed |
11-18-2010, 04:50 PM | #19 |
Rep 1,084
Drives: 2013 BMW F10 550 Xdrive Msport
For now, I just ended up Professionally wiring a set of Xenons for my own car using Butt connectors and tying directly into the factory harness connectors (Helps being a network engineer with an electrical degree). Can't even tell that it was converted by looking at it! Tested em out with no errors and doing the permanent install this weekend. I will make sure to document whole procedure for anyone interested.
I WILL attempt the FULL OEM retrofit when the weather gets warmer, I have a lead on a guy that sells the wiring kit from BMW, but then you have to find the foot control unit and the headlight switch used as if you buy them new it is like 400-600 dollars just for those parts. |
11-29-2010, 09:21 PM | #20 | |
Rep 12
Please upload your results! After reading all the xenon convertion threads, I just get more confused than ever! If someone gets ALL OEM PARTS(housing, bulbs, ballast...), and just replace the halegon, would that be error freee, or what else you need to do to get them working and stable(I do not need the adaptive function, just need them light up and no error).Thanks.
12-02-2010, 02:13 PM | #21 |
Rep 13
I did not realize you have to take off the bumper and all the other issues. I was going to buy these http://www.carid.com/2007-bmw-3-seri...ml#fullInfoTab and do a plug and play. I guess not.
12-06-2010, 05:40 PM | #22 |
Rep 402
I've got a set of bi-xenon adaptive headlights with the factory ballasts and factory modules that I want to convert/use in my halogen car. I don't care about the adaptive part (ride height and that they turn into the direction car pointed). I just want them to work in my car. I've read the threads on this type of conversion, but was wondering if you could use the factory harness you used and whether it would cause any errors if I don't get a new footwell module.
Mike, do you have pictures of the work you did to tie into factory harness? I'd prefer not to have to cut wires if possible. My car is a e90 build date 02/07. What is your build date (I note that it seems to matter if the car is 02/07 and earlier vs. 03/07 and later. The 02/07 builds are KCAN or something like that and the 03/07 builds are DCAN. |
