The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > removing caliper paint help?
Reply
      11-24-2009, 12:59 AM   #1
Sam12345
Sam12345's Avatar
106
Drives: jet black 335i coupe
2008 335i Coupe  [0.00]
Basically i have painted calipers on my 335 and was wondering how can i remove this?
I tried regular brake cleaner and that did not work, so i figured i should use some Aircraft Cleaner(strong paint thinner).
Will i need to bleed the brakes in order to do this? Or can i just use paint thinner on brakes with just the pads removed?
I have also heard brake fluid removes paint right off, would i be able to use this without having to take off the brake pads?
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
      11-24-2009, 01:37 AM   #2
tkillips
Casual Modder
12
Drives: '08 E92 BMW 335i
Why are you thinking of removing this mod? Just curious as I was thinking of doing this myself.
      11-24-2009, 05:17 AM   #3
Former_Boosted_IS
Drives: 4 Wheels
I have used an abrasive metal brush in the past and it worked like a charm.
      11-24-2009, 06:21 PM   #4
Sam12345
Sam12345's Avatar
106
need to put the car to stock!
will try this in a few hours.
      11-28-2009, 03:10 PM   #5
dvpouldar26
dvpouldar26's Avatar
64
Drives: 2008 e92 328i, Porsche 987.1
Sam, spray it with a few coats of goo-gone and let it sit, then go over it with a wire brush. Should take it off. If not, use parts solvent,or spray it grey like the stock color.
E92 328i
Jet Black / Gloss Black Grilles / 8000k D1S low beam / 6000k HID fogs / GP Thunder 8500k angels & cornering bulbs / black reflectors / gloss black vinyled window trim / tints / smoked rear turn signals / black roundels / AC Schnitzer roof spoiler / VRS style decklid spoiler / Matte black Stripes / Rear fogs / matte mirrors / 19" LM reps / APR lip
      11-28-2009, 07:22 PM   #6
montreal red
chris
montreal red's Avatar
Drives: White Boat
pour some thinner over the calipers and then rub using very fine grit sandpapers... the paint should come off.... sand paper grit should be 1500... if you use rougher grits, it will leave deep gouges on the surface of the caliper.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      11-28-2009, 08:15 PM   #7
redfred18t
Drives: 07 335i
can you just spray paint it like black and be done with it?
      12-01-2009, 11:50 PM   #8
Sam12345
Sam12345's Avatar
106
My concern is this might damage the brake pads, otherewise id be spraying aircraft cleaner all over that bitch lol.
considering this
      12-02-2009, 02:15 AM   #9
dvpouldar26
64
considering this
3 things you could do:
1. Paint them black and hope your SA doesnt care.
2. Mask off the rotors and pads and use the paint remover and wire brush.
3. If you can, remove the caliper and pads (not that hard at all, if you have the tools, try the DIY), then remove the paint.
I will tell you right now that I dont think parts solvent will have any mal effects on your brake pads, etc. I occasionally clean my calipers with parts solvent.
If you just respray it silver to match stock, I doubt the dealer would ever notice.
E92 328i
Reply
