Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY - LED licence plate lights and door entrance lights
Reply
      10-15-2006, 04:18 AM   #1
rikuF10
Hong Kong
81
Drives: F10 G29
2019 BMW Z4  [0.00]
2012 BMW 528i  [8.50]
Since the ECU is monitoring the current of any exterior light, changing to a LED bulb will trigger the error message.
In order to avoid the error message, you will need to fool the ECU that you are using the correct power consumption.
This is what I used in my LED licence plate light mod...
1) an extra pair of Licence plate light housing (less than US$6 for a pair)
2) Three 25W 220 Ohm resistor w/ metal heat shink. (pls note the resister value will vary with different LED bulbs)
3) some Telfon coated cables and Telfon tubes
4) a few Nylon ties
5) a soldering iron and some solder
6) two 37mm 6LED bulbs
I bought a new pair of the licence plate light housing, so that I can easily reverse the process........when I bring my car into service, they won't even know I did anything to the lights.
For the telfon cables.....actually, you can use regular cables. I only use it for added protection.
Just one more reminder: DO IT AT YOUR OWN RISK
      10-15-2006, 04:20 AM   #2
rikuF10
Hong Kong
81
Drives: F10 G29
2019 BMW Z4  [0.00]
First, you have to take out the licence light housing. Just put a flat screwdriver into the hole to the left of the plastic lens.....push to the right & pull the housing down.
Then just pull off the plugs.
      10-15-2006, 04:27 AM   #3
rikuF10
Hong Kong
81
Drives: F10 G29
2019 BMW Z4  [0.00]
Then you need to solder the 3 resistors to the housing. I am running them in parallel. Since the two lights are running in parallel, it doesn't matter where you install the 3 resisters. For the cable length, 30cm is good enough.
I put two to the left housing and one to the right housing.
In first photo, you can see a small resister at the right. It is actually good enough to just use this one. However, it will gets very hot. For safety, I divided the load to 3 extra large resisters.
      10-15-2006, 04:33 AM   #4
rikuF10
Hong Kong
81
Drives: F10 G29
2019 BMW Z4  [0.00]
Now, install the modified light housing back to the trunk lid. and secure the 3 resister with nylon ties.
I found there are 3 good places to put this inside the trunk lid...
      10-15-2006, 04:35 AM   #5
rikuF10
Hong Kong
81
Drives: F10 G29
2019 BMW Z4  [0.00]
Now put the trunk lid lining back.....and it is done! :rocks:
.....also noticed that my blacklines has no white lights leaking at the edges? ....just replace all four P21W bulbs with a red color bulbs. Not only will there be no white light leaking out, the blackline also looks cooler at night!
      10-15-2006, 05:04 AM   #6
rikuF10
Hong Kong
81
Drives: F10 G29
2019 BMW Z4  [0.00]
For the door entrance lights, it is not being monitored by the ECU....so you don't need anything to fool it.
For this mod, I am using a 6 LED plate. On the passenger side door, I put the LED plate right behind the plastic diffusor, so doesn't really get to be diffused. The result is 6 bright LED squares projected to the ground (with three dimmer ones as bonus). Looks kind of
      10-15-2006, 05:07 AM   #7
rikuF10
Hong Kong
81
Drives: F10 G29
2019 BMW Z4  [0.00]
On the Driver side, I put the 6 LED plate with a clearance of approx 1cm to the diffusor. I get one large bright lights. This illuminate the floor very well....make sure I don't step on any shXT when exiting the car...
      10-15-2006, 06:03 AM   #8
cntlaw
cntlaw's Avatar
Hong Kong
235
Drives: 330i E90 C55 AMG
WOW ! Thank you for your kind sharing with these wonderful E90 LEDs works with us.
BMW 2006 330i E90 Jet Black/Black Leathers/Aluminium, Steptronic Active Steering; MTech Aero Kit Carbon Fibre Splitters/Diffuser. Bilstein PSS9 Coilover, Rays VOLK Racing RE30 Formula Limited Edition 18" Pirelli Rosso; Project Mu 355mm Forged 4pot Caliper. HID:Osram D1S 6000K, PIAA 6500K White Ring, Philips Diamond Vision HB4 5000K, PIAA H490/H491 Super Bright 6500K LED Interior Lights. Chrome S.Wheel Cover, Rear Windows Sunshades.
      10-15-2006, 07:32 AM   #9
HO
HO's Avatar
Drives: E90 325i
Danny, Excellent job
      10-15-2006, 07:48 AM   #10
RD Sport
Freude am Fahren
114
Drives: from Deutchland
D, thanks and good job on the rear license, I am going to get mine installed shortly. Hopefully we will be able to sort out my int. LED project
      10-15-2006, 08:46 AM   #11
sunnywuh
Drives: E90 330
you are the man!!!
      10-15-2006, 09:04 AM   #12
DILLIGAF
Drives: 2006 SG 330i ZSP MT CA
2006 330i  [0.00]
Nice DIY
2006 330i
Sparkling Graphite/Sport pkg/Comfort Access/Aluminum Pedals/35% LLumar tint/Blacklines/OEM Shortshift knob
      10-15-2006, 11:35 AM   #13
SocalTy
Flushing, Queens stand up!!
SocalTy's Avatar
35
Drives: AW E90
06 e90  [0.00]
Wow. Great DIY! Think I'll try this in the upcoming weeks.
l 20% Tints l Osram 6000k Xenons l Brex l Blacklines l White Led Sidemarkers l PIAA Superwhite Turn Signals l 19" Breyton Spirits l H&R Sport Springs l Koni Yellow Adjustable Dampers l ACS Roof Spoiler l Painted Carbon Spoiler l Luminics Fogs l Oem Chrome Grill l
      10-15-2006, 12:41 PM   #14
Leonardo629
Taiwan
168
Drives: 2013 M3 Coupe
nice.....
      10-15-2006, 12:44 PM   #15
RichP
RichP's Avatar
Drives: F80
Excellent writeup. I especially like how you used the resistors with a heatsink, which is a necessity in these applications.
      10-15-2006, 08:08 PM   #16
kelvinso
kelvinso's Avatar
22
Drives: BMW 320i E90 TiAg/Lemon
Great and nice job
Next Q: When should I mod mine??
      10-15-2006, 09:44 PM   #17
EBMCS03
M5 Extraordinare!
Drives: GC shopping
Excellent! I hope the rear licence plate is the same for the E60 or very similar... I've been wanting to do that for like a year.
2008 ///M5 SMG | Alpine White | Black Full Merino Leather w/Aluminum Trim | Logic 7 | iPod Adapter | HUD | Heated / Ventilated & Adaptive Comfort Seats | Comfort Access | Rear Side Airbags | Rear Side Sunshades | Folding Rear Seats | 35% Sides 15% Rear Windshield Tint
      10-15-2006, 09:56 PM   #18
rikuF10
Hong Kong
81
Drives: F10 G29
2019 BMW Z4  [0.00]
On the E60, it is very similar since the licence plate light bulb is the same 12V5W. The only thing is to buy the equavilent LED bulbs and test the difference in power consumption. Then use the corresponding resistor value.
      10-15-2006, 10:01 PM   #19
rikuF10
Hong Kong
81
Drives: F10 G29
2019 BMW Z4  [0.00]
Originally Posted by kelvinso
Great and nice job
Feel free to come & take a look before deciding to mod it....
Let's have a mini HK LED meet!
      10-16-2006, 12:20 PM   #20
txusa03
Drives: TS330iPPSP6MT
nice writeup, always thinking ahead...
the door light is cool bro with the 6 small led shooting down the ground...
      10-17-2006, 12:02 AM   #21
joebaggg
E60
joebaggg's Avatar
Drives: Black Attack
2006 E90  [0.00]
hey i set off the ECU when installing led's in the headlights, i believe its the parking light (the peanut bulb) any idea how i can fool the ECU for that?
      10-17-2006, 12:03 AM   #22
EBMCS03
M5 Extraordinare!
Drives: GC shopping
Sounds like a plan.
Reply
