BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > My recent 6MT Oil Change Story
Reply
      02-11-2010, 05:07 PM   #1
HRC
MAUI BUILT
HRC's Avatar
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
Arrow My recent 6MT Oil Change Story
After the last 3 years (my daughter) of following the dealer recommended oil changes to not prolong your cars value (and having time on my hands) I changed the oil in my wifes TSX (I hate FWD) so I was inspired to go back and to mine.
I could not loosen the oil filter cap as I have done many times with my strap wrench. Tisher sells them for $30k I found one on my local Snap On truck for $19.95.
Second, oil was dirty but I don't have a clear idea of when my oil was last changed at the dealer. Several clips and the "trap" door are now missing to my oil drain plug. Wow. Top that, the washer on the drain bolt was doubled up. Well, forget it. I'm glad I had a chance to re-connect with my car.
So today, I decided to change the 6MT fluid with Royal Purple Synchromax. Reading the treads, just under 2 quarts were needed. Removing the filler bolt did not spill any old fluid. I used about 1/3 of a Royal Purple quart to flush the gearbox and used the rest to fill it up. About a little more than half or less of the second bottle, the tranny started leaking! Well, at least it was clean and purple. I plugged it up while it was still leaking kinda slowly.
Any chance of over fill?
Test drive now...
TIA,
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
      02-11-2010, 11:53 PM   #2
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
Pics of Enigine oil/mt tranny change
Some pics changing the tranny fluid today using RP Synchromax.
Danny
      03-10-2010, 04:06 PM   #3
battlehawk1025
battlehawk1025
battlehawk1025's Avatar
Drives: 2007 335XI 6mt, SL 65 , M6
DUDe if im right that filter is for the OIL i could be wrong
      03-10-2010, 05:01 PM   #4
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
Your right, I was changing the oil at the same time and also include those pics. The long funnel like contraption is what I used to change tranny oil. During th engine oil change, I cleaned that oil filter canister pretty OCD'ish...
Danny
      03-10-2010, 06:47 PM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10616
Drives: N54 e82
So what happened with your leaking tranny>? Where was the leak and did you get it fixed?
      03-11-2010, 10:18 AM   #6
LetsRock
LetsRock's Avatar
Drives: 2007 328xi
2011 328xi  [0.00]
2007 328xi  [0.00]
I changed the oil on my "new" 2007 328xi this morning before going to work. I picked it up with 49K miles and so a "free" oil change was not going to happen before the warranty expired.
I did not realize that so much oil was in there and it overflowed my pan and spillled on the garage floor. Oops!
Now I just have to surf this site until I can find how to reset the computer.
      03-11-2010, 12:14 PM   #7
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
The leaking part only came on the refill part. Once the fluid reaches max (the fill hole level), the tranny is full, new fluid starts coming out and you can plug it up. My tranny never leaked after the change.
Danny
      03-11-2010, 05:49 PM   #8
jonerik26
jonerik26's Avatar
Philippines
58
Drives: black 335i e90 PRE-LCI
2007 335i  [8.00]
1998 Acura Integra  [8.50]
2006 325i  [8.00]
easy.... put in key, turn on car, but dont start it... wait til dash screen is clear of everything with simply the time on it, push down the odmeter button, hold until a triagnle image appears, while still hold the odmeter button, push the BC button and should bring you into the service menu, from there simply cycle through and use the BC button to reset
Reply
