BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > How Do I Check What Progman Version I Have?
Reply
      05-21-2007, 04:15 PM   #1
hl0m4n
hl0m4n's Avatar
Drives: BMW
Post How Do I Check What Progman Version I Have?
is there a function in the car to see what progman version i have so i can look up the problems on this forum based on my progman version? has anyone thought of using the sos button and askin straight up?
      05-21-2007, 04:34 PM   #2
Enkur
Enkur's Avatar
Drives: 2022 M3 Comp xDrive
2011 BMW 328i  [0.00]
I hope there is a way to find that too .. I dropped off my car at the dealer this morning with the understanding they are going to update my idrive with the new update (I told them I had problem with the pop up arrows). I get a call back later in the day from the tech saying that he went into irdive and changed the setting that would take care of it. I told him "there is no setting to change I have gone through every setting." then he says he will look into it more. Calls me back again saying what I am looking for requires a NAV disk and I would have to order it!!! I swear I just wanted to bitch him out. I told him calmly I made the appointment with the supervisor with the understanding they are going to update the idrive software! Lets see what he calls back with. I may need to print out the damn TSB and show those fools.
2022 Tanzanite Blue ///M3Cx ||| 2015 550i ||| 2011 328i sedan ||| 2009 Z4 ||| 2007 328i Coupe
      05-21-2007, 04:38 PM   #3
hl0m4n
hl0m4n's Avatar
Drives: BMW
Post
same i hate that too. dealerships just making excuse after excuse. so now i want to know what version i have, print out the sheet for the errors on my software and prove them wrong.
what is TSB?
      05-21-2007, 04:43 PM   #4
Enkur
Enkur's Avatar
TSB= Technical Service Bulletin
      05-22-2007, 01:59 PM   #5
Enkur
Enkur's Avatar
woohoo .. got the idrive updated to 25.01 ... I like the colors .. very clean. The response time is much quicker.
      05-28-2007, 06:27 PM   #6
hl0m4n
hl0m4n's Avatar
Drives: BMW
v25.02.00 or v25.01.01
      06-20-2007, 07:11 PM   #7
GameGod
GameGod's Avatar
Drives: 2018 440i
Question Progman version?
Hi,
New owner to bmw's and i've been lurking and searching. Very informative site.
I found the sequence of i-drive clicks needed to get into the diagnostics screen on my 07 335 sedan. I want to find out what version of progman i have. However, this post refers to target data status which I can't find anywhere. I have items like c-host, applikation, etc.
If it helps, it says build date 21-03-2007 in almost all the screens.
Can somebody please help me figure out how to determine what progman version I have?
Thanks!
      06-21-2007, 08:07 AM   #8
cobradac
cobradac's Avatar
20
Drives: '05 645Ci Coupe
2005 645Ci  [0.00]
There is no way to check PROGMAN version in iDrive equipped vehicles. Claims to the contrary are just not valid. Any success in this regard has only been attributed to non iDrive cars, but I cannot independantly verify that.
Only the dealer can tell you by hooking you up to his equipment or by delivery spec if you have not upgraded since taking delivery of new car.
Build dates of 03/07 and newer will have PROGMAN v25.xx.xx
Here is a pdf on the E9x series PROGMAN versions since SOP.
Also included the introduction SIBs which may capture your build dates and provide you with some information IF your build date coincides with the dates contained therein. Unfortunately, I did not save the Nov 06 bulletin of SIB 000206.
      06-21-2007, 08:44 AM   #9
GameGod
GameGod's Avatar
Drives: 2018 440i
Wink
Thanks a lot! It seems like I have 25.01 since my RTTI and VR commands work. I also have the new colors and POI search capabilities.
How do you get the SIB pdf's? Are they posted on here somewhere?
Thanks.
      06-21-2007, 10:47 AM   #10
cobradac
cobradac's Avatar
20
2005 645Ci  [0.00]
Thanks.
I make and post them as I am sure others do from time to time.
      06-21-2007, 12:42 PM   #11
GameGod
GameGod's Avatar
Drives: 2018 440i
Thanks, I'll keep an eye out for them.
      06-21-2007, 01:19 PM   #12
jreaton
Drives: 335i Coupe Saddle Brown, Nav,
When speaking with service techs its important to very literal. If you want to upgrade the I drive software it is the disk. When you want to upgrade the total software it's the Program Software.
335i Coupe Jet Black, saddle brown, nav, pdc
      06-21-2007, 08:16 PM   #13
Bimmerforlife
Drives: E90 335i
I wonder how up to date cars on the assembly line are in getting the most recent Progman versions. For instance do the June built cars get the latest Progman from March and then are updated at the Vehicle Preparation Center? Or not updated at all or maybe they get the latest Progman on the assembly line.
      06-22-2007, 07:25 AM   #14
SteveMD
SteveMD's Avatar
196
Drives: 2016 F10 535i MSport
The DVD contains only the map data from Navteq. There is no iDrive 'software' on the DVD.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      11-06-2007, 03:29 PM   #15
cobradac
cobradac's Avatar
20
2005 645Ci  [0.00]
UPdated PROGMAN (Formerly CIP) list.
      11-06-2007, 06:04 PM   #16
drfluid
drfluid's Avatar
Drives: 2006 - 330i Navi, Premium
can anyone read this?
330i-NAV-Premium
      11-06-2007, 07:59 PM   #17
cobradac
cobradac's Avatar
20
2005 645Ci  [0.00]
I suppose if you cannot "save picture as" and then use in paint or other photo program I suppose you could use this Adobe file.
      11-06-2007, 09:24 PM   #18
zenmaster
Drives: '17 M2
The jpeg picture is not auto-scaled. you uploaded a bad image.
      11-08-2007, 03:53 PM   #19
Iceberg
Engaged
Iceberg's Avatar
Drives: '07 335xi
Confirmed. Saving and zooming do not help. Thanks for the pdf tho. All good.
335xi Monaco Blue/Grey Leather and Poplar Wood Trim
Premium pkg, Cold Weather pkg, PDC, Comfort Access, On-board Nav w/ iDrive
Sirius, iPod/USB adaptor, Rear Sunshade
      11-08-2007, 09:57 PM   #20
cobradac
cobradac's Avatar
20
2005 645Ci  [0.00]
It seemed to on other software ( it would open in new window and could zoom to be legible) - didn't realize it would not here as well. Oh well, I assume the adobe was satisfactory?
Reply
