Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > Autocross with e90 335i stock tire pressure?
Reply
      05-24-2007, 03:50 PM   #1
asdfaa
asdfaa's Avatar
Drives: bmw
I am going to a autocross class and they talked about raising the tire pressure by about 10-20psi over normal before going to the track. Should I add about 10psi to my stock tires (sports package)? Is that recommended with RFTs? Anybody else have experience with this?
2010 335i xDrive Sedan
Saphire Black Metallic | Saddle Brown Leather | M Sport Package |
2008 X5 4.8i M Sport Edition
Ruby Black - Individual | Saddle Brown leather | Bamboo Trim | M Sport Package |
      05-24-2007, 04:11 PM   #2
leftcoastman
Drives: 335i
Running at stock pressure will result in very chewed up tires, especially front. You should see my tires.
      05-24-2007, 04:25 PM   #3
S4to335
8-10 maybe..not 20 lbs over recommended pressure.
Car is now gone .... :-(
      05-24-2007, 04:26 PM   #4
asdfaa
asdfaa's Avatar
Drives: bmw
For the autocross should the pressure be the same in all 4 tires? At the class they said for rwd to have all 4 tires at the same pressure.
The manual says that the fronts run at 32 and the rears at 38.
      05-24-2007, 04:34 PM   #5
oneshare325
oneshare325's Avatar
Drives: E90 325i, E82 135i
2018 BMW M3  [0.00]
2006 325i  [0.00]
yea 20 sounds like ALOT!
      05-24-2007, 11:53 PM   #6
asdfaa
asdfaa's Avatar
Drives: bmw
i ran 42 all around, hard to tell the track was rainy and wet
      05-24-2007, 11:54 PM   #7
ward
Drives: F
you don't need to bump them up quite as high as non runflats
but you should have at least 40 psi in all 4, probably 42 front 45 rear or so
      05-25-2007, 12:18 PM   #8
shimshimhada
shimshimhada's Avatar
Drives: Portal
I run 38f 32r for less understeer at autoxes. Or you can do real overinflation in the rears for mad oversteer.
Reply
