BMW 3-Series (E90 E92) Forum
Need help with headlight issue!!
01-22-2012, 11:05 AM | #1 |
Rep 738
You guys don't understand how much I've researched trying to find a solution to my problem...haven't found anything yet. I need to figure out a solution, so please guys anything can help.
It's an 06 330i. Xenon d1s bulbs. My left headlamp (drivers side) is being weird..sorry but for a lack of a better term. It's hard to describe, but the light doesn't seem contained in the projected area.. If you compare it to my right headlamp, it looks how a normal xenon would look. My left one is just doing its own thing over here haha. I'll try to get some pictures to try and show you guys what I'm trying to say. Also, the AE on the right headlamp seem fine, but my left headlamp AE seems messed up. It might be because the light from the bulb is overlapping the AE. Like I said, it just doesn't seem contained. I replaced the bulbs, but that wasn't it. For a better description, the right headlamp seems to be a bluish white color while my left headlamp seems to be a very bright white. Right headlamp Left Headlamp
2015 AW/SO 6MT F82 M4
01-22-2012, 12:01 PM | #2 |
Rep 92
Take the bulb and ballast out of the bad headlight and swap over to the good one. See if the problem follows the headlights or the xenon.
Once you've done that you can rule out bulb/ballast. Then swap over the physical headlights from one side to the other and plug in (if you can). If the problem follows the headlight, then it's the headlight, if not then it's down to the FRM or the wiring. |
01-22-2012, 01:06 PM | #3 |
Rep 738
Sounds good. If you don't mind me asking, how would I go about removing the ballast?
It's definitely not the bulb because I've Replaced the bulbs. I think it could be from the actual headlight, but I'll try plugging In my right one and go from there. Could firmware be an issue?
01-22-2012, 01:21 PM | #4 |
Rep 3,561
I'm afraid this might be a physical deal where maybe one of the projector mounting points came loose/broke off from a pothole or hard bump.
If you're OK with taking stuff apart, I'd personally just pull the headlight apart from the back and remove the projector and inspect it. It's a good bit of work and you need to be very careful, but that should give you the answer you need. Definitely try swapping ballasts before doing something like it though. |
01-22-2012, 01:27 PM | #5 | |
Rep 738
Hypothetically speaking, if the ballasts were to fail, wouldnt the lights just not turn on? Or would a ballast fail give you a discoloration?
01-22-2012, 01:38 PM | #6 | |
Rep 738
I feel like it might be the mounting for the projector. I have CPO..would it be covered under that? Any other ideas?
