BMW 3-Series (E90 E92) Forum
Heel Toe Technique
07-20-2007, 05:31 PM | #1 |
Rep 134
Heel Toe Technique
Can any offer any advice for mastering heel/ toe technique. I can not get this to save my life. I think I'm fundamentally doing something wrong.
07-20-2007, 06:20 PM | #2 |
310
Rep 15,745
its a PITA to do in the bimmer. Im pretty well accomplished at it, but the drive by wire throttle response absolutley sucks when the clutch is disengaged...a small blip gets like 1200 rpm, and it goes back to idling.
My 240 was awesome..whoever said drive by wire was faster than a cable actuated one must be off their rocker. |
07-20-2007, 11:08 PM | #3 | |
Rep 181
Drives: 2006 911 Carrera S
Hope this works for you!
2011 X5d Platinum Grey/Oyster/Bamboo/+lots of stuff
2006 911 Carrera S - 6MT - Seal Grey/Black/Sport Seats/Sport Exhaust/Sport Chrono/Nav Gone: 2007 E92 335i - 6spd - MontegoBlue/Black 2003 E39 530i - Auto - Black Sapphire on Black Gone: 2001 325Ci - 5MT- TopazBlue/Black Trackday Count: 10 |
07-21-2007, 12:47 AM | #4 |
Now With 33% MORE Sarcasm Free!
157
Rep 3,462
Ell and of course be aware that it's NOT really HEAL TOE anymore... Not really.
It's more Big Toe Brakes Little Toe Blips... But ya prolly knew that. Also the OEM Peddles are not properly spaced if you are wearing any sort of driving shoe, they are too far apart.
A BMW is Just a Car, it doesn't make you smart, handsome, clever, better, cool, or wealthy. |
07-21-2007, 01:02 AM | #5 | |
Rep 46,029
do not try heel-toe, try ball of foot vs. knife of foot, try it while the car is parked but may want the car on. If you give the engine too much gas while it's off it might not start and you might need to roll it to start it (at least on old cars this used to be the case) |
07-21-2007, 06:03 AM | #7 |
Rep 144
Can't flood an engine without a throttle linkage!
08 Cayman S
07-21-2007, 01:50 PM | #8 |
Rep 648
It is always fun to see real heal and toe in action. There have been some good in car videos, one NASCAR in particular where you actually really do use your heal to brake and your toes to blip the throttle. Most sedan street car pedals are not set up for this "original" technique.
07-23-2007, 03:54 AM | #9 |
born to be turbocharged
24
Rep 1,347
check this out:
http://www.turnfast.com/tech_driving..._heeltoe.shtml also the whole site content is a nice read for all of U tracking the car out of the straight line, start @ the beginning. |
07-23-2007, 11:39 AM | #10 |
Rep 2,317
The trick to doing heel/toe is to do it ALL the time! I do use the big toe/little toe technique. But again I'd make sure you are really familiar with it before you use it on the track. I had it down on my e46 but still working on how much gas to give on the e92.
07-23-2007, 04:45 PM | #11 | |
Rep 134
07-23-2007, 05:08 PM | #12 |
Rep 1,760
07-23-2007, 07:39 PM | #13 |
Rep 1,714
Get a wider pair of shoes. I wear some stylish leather tennis shoes that just happen to have a super wide ball-of-foot area. Like others said, it's more bigtoe/knife edge rather than heel/toe.
And practice everywhere. When I'm heading to a stoplight, I'll row down through the gears, even if I'm lightly applying the brake. Be careful that you focus on the brake - better to screw up the blip than screw up the braking as you're entering a turn at 135mph and need to slow to 60mph for the turn-in! |
08-08-2007, 03:13 AM | #14 |
Rep 812
I am trying heel toe, as it's annoying to not be able to do a smooth downshift while braking.
I think problem with bimmer is that the level of the gas pedal depressed is where the brake is fully pressed. A floor mounted pedal makes things even harder as ur heel will press on the pivot point of the gas pedal if you actually try 'heel' and toe. Last but not least the gas pedal is right at the edge of the footwell (my old accord had probably 2 inches from the edge of the pedal to the side of the foot well), making heeling the gas difficult if you have a large foot. The roll foot technique works but I find it hard to control gas and runs the risk of slipping on the brake pedal. Moreover using this technique I have to angle my foot a lot to be able to floor the pedal if needed (3rd to 2nd at 3k rpm almost want a floored blip). Since I have a small Asian foot, I am trying to actually get my foot to step on the brake more towards the left (away from the gas pedal) and actually heeling the gas. Stepping more towards the left on the brake is needed otherwise your heel hits the footwell side wall... I don't know if this is a good idea at all as compared to the roll foot method. I was watching the CTR FR2 test drive by Best Motoring. It was also a floor mounted gas pedal and the Tsuchiya was actually doing a full heel toe as I described above rather than a roll foot technique. On the other hand however I also saw Jenson Button driving the FR2 and the clip shows him doing a roll foot technique..... Anybody able to describe the pro's and con's of the two different techniques? Maybe one is more proper than the other by any chance? |
08-08-2007, 10:02 AM | #15 |
Rep 3,469
Whats the advantage of heel toe shifting? Ive never done it.
2016 Alpine White M3 (gone)
2019 Alfa Romeo Guilia (Totaled) 2020 Car-less 😁 (no more) 2020 M340 |
08-08-2007, 10:33 AM | #16 |
Rep 191
Fraggy, the idea is to match the engine revs for a smooth downshift while braking. For most street driving, it's for the ultimate in smooth driving. In a racing situation, it's necessary; if you're at the limits of traction while braking into a corner and you downshift, dumping the clutch will jerk the entire car from engine braking, and you'll spin.
The link above explains it all pretty well.
Scarecrows25
Jet Black E90 328i / 6MT / Sport / Xenons / Split Fold Rear Seat / OEM Chrome Exhaust Tips |
08-08-2007, 12:01 PM | #17 |
Rep 2,317
BiscottiGelato - You should be able to use the roll technique. I have a very small foot 9 narrow and it works for me. Better when I'm wearing regular tennis shoes than work shoes because they have a bit of a flare. You don't need to floor the gas just match the RPM's which isn't too much gas as it should be out of gear when you are doing this.
The real racers have a totally different car that requires a different technique. For street cars and for bimmers the roll the foot works very well. You also mentioned that the brake needs to be fully engaged before you can feel the gas. How many miles do you have on your car? I felt this when it was very new. However as I put more miles on it the brake pedal went down significantly. At about 2K miles it was about even with regular braking. Now it lines up pretty well (4K miles). |
08-10-2007, 01:00 AM | #18 | |
Rep 812
08-10-2007, 08:38 AM | #19 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
Pics
This is a reply I posted a while back on the same subject.
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
08-10-2007, 08:50 PM | #20 |
Rep 332
Drives: 330xi
Search youtube for "Heel and toe" to find demo videos on the techniques
330xi Sparkling Graphite | Terra with Burl Walnut | ZPP | ZSP with Style 162 | Comfort Access | Heated Seats | PDC | Navigation | Satellite Radio | OEM Alarm | De-badged | OEM Strut Brace | Blacklines | Rear Fogs | Silver Front Indicator Bulbs
Ordered: 4.3.2006 Scheduled for Production: 4.7.2006 Awaiting Transport: 4.13.2006 En Route: 4.19.2006 At Preparation Center: 5.11.2006 Performance Center Delivery: 06.01.2006 Last edited by mosport70; 08-10-2007 at 09:03 PM.. Reason: added link |
08-11-2007, 01:05 PM | #22 | |
MAUI BUILT
485
Rep 7,781
Next - Double clutch... Danny
