09-06-2012, 08:55 AM | #1 |
Rep 1,063
HK Sound System: Suggestion for Improvement
Maybe I'm the only one that has noticed this, but wouldn't it be nice if the HK Sound System allowed for "easy switching" to preset sound profiles on the equalizer (like Jazz, Deep, Vocal, etc)? Some songs sound a lot better with different settings than others, and it's a pain in the a$$ to go into the equalizer and manually adjust each band for every song. Even the 2008 Chevy Cobalt had this feature...c'mon BMW!
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3 |
09-06-2012, 09:05 AM | #2 |
Dinosaur supervisor
3030
Rep 4,214
Yes, I would like something like that to. Now it feels like I have to adjust it for each song I listen to. Maybe this is because I just got the car, but if feels like I have to make small adjustments all the time.
Is there a thread where people list their equalizer settings somewhere around here? I know that E90Post had this, and it was a big help when someone with the right equipent did a calibration. I know it's not one setting fits all, but it was a great starting point. |
09-06-2012, 09:25 AM | #3 | |
Rep 1,063
09-06-2012, 09:38 AM | #4 |
Rep 5,803
not possible, maybe you can use one of the presets, but i doubt it.
i always listen to edm so i never really thought of this, older bmw's had it
F30 330i Alpine white/Coral red Msport 6MT
09-06-2012, 10:09 AM | #5 |
S0THPAW
8719
Rep 7,846
I even UNclicked L7. Many songs sound better then.
The reception/sound of the radiostations is 9/10 times just poor for such an expensive system. The songs on my iPhone via the HK system sound 100% better it seems(Thank God). Strange. Cheers Robin |
09-06-2012, 10:14 AM | #6 | |
Dinosaur supervisor
3030
Rep 4,214
I can stream the audio with bluetooth, but that kills the battery in 2h. And if i plug it in with the USB-cable is have to kill bluetooth audio. The sound still plays fine, but the controls doesn't work (to change songs) and no info about artist, album, song title anymore. I need a Spotify app! |
09-06-2012, 10:29 AM | #8 |
Dinosaur supervisor
3030
Rep 4,214
I know, I use it all the time. It was the one I used in my post above. What I meant was an BMW App (made with the SDK), like Pandora. So that I can get full control with the iDrive instead of just BT-streaming.
09-06-2012, 10:36 AM | #9 |
Rep 1,063
Maybe I need to mess with the EQ on the iPhone under the Music section of settings. However, I was always under the impression that you should leave this to 'Off' when playing music through the iDrive.
09-06-2012, 10:49 AM | #10 |
Rep 5,803
ahhh, i see
09-06-2012, 10:52 AM | #11 |
Rep 163
I always leave my EQs flat - I can't stand artificially increased EQ's. A good audio source always helps aswell - if you're using mp3 or m4a's, they are lossy and one of the first things they do is cut the very top and very bottom ends off the waveforms as most people can't hear the difference. That's why CD's or lossless always seems be to more "punchy".
Lossless for me all the way Last edited by dave-the-rave; 09-07-2012 at 02:11 AM.. |
09-06-2012, 11:13 AM | #12 | |
Rep 1,063
09-06-2012, 11:43 AM | #13 | |
Rep 163
09-06-2012, 12:49 PM | #14 |
iX1 2022
35
Rep 333
The problem with the HK is that it must be lowered, not increased. One should use the EQ to lower the bass frequencies. There are threads about this for the E90 and it makes hell of a difference. Flat is useless in this car.
Here is one thread: http://www.e90post.com/forums/showthread.php?t=42672 Last edited by Micleg; 09-06-2012 at 12:55 PM.. |
09-06-2012, 02:22 PM | #15 |
Rep 517
Let the speakers run in. It should sound a lot less harsh after around 100-200 hours of playback. The cones are still very stiff up until then so they need time to loosen up and improve the dynamics. Also, use CD or Apple Lossless on an iPhone/iPod.
09-06-2012, 06:27 PM | #16 | |
Güten Täg
12
Rep 161
ALE, ALAC and for the real enthusiast FLAC are the "lossless'' formats, FLAC will eat storage space very quickly.
2013 F30 328i Sport 6MT MG
1991 E30 318iC 5MT M20B25 swapped Vert Black - gone |
09-06-2012, 07:14 PM | #17 |
Rep 517
ALAC is just as good as FLAC and it has better compression (still lossless though) so the file sizes are slightly smaller. Yes, the extra compression requires more power to decompress but there's nothing these days that can't handle it. Also, ALAC is supported on iPods/iPhones, it's much better for tags and album art, and finally it's now open source!
09-07-2012, 02:12 AM | #18 |
Rep 163
09-07-2012, 10:27 AM | #19 |
Rep 1,105
I tried playing flac off of flash drive my m3 won't play;( so I have to burn on cd and transfer ? Is it possible to transfer to apple format in iTunes and play from flash drive or transfer from flash drive
09-07-2012, 11:50 PM | #20 |
Rep 7,047
The HK is nice, it's a step above the stock system.
But for the price, it's not up to it's cost. Satellite stations have poor sonic quality. It's nice that it's a "clean" signal, but it's quality is ultra compressed. The problem I'm having with mine is FM reception. It's bad. I can't believe I spent all the extra money and BMW and HK can't even make a good antenna. We have HD channels of FM stations, and if you can "catch" it it sounds better, good even. But, even with the strongest stations the FM receiver can catch and hold it. It cuts back to non HD. On some of those same strong FM stations I get hiss, quick signal loss and then back again. It's freaking annoying. Cheapo FM radio's can get and hold these stations. My 135i's standard system always held these stations. I'll put it in the list for the tech's to check out. I'm really hoping there is a loose antenna connection. If not, I want a new receiver, and if that means a new head unit, then so be it. Anyone else have poor FM reception? |
