BMW 3-Series (E90 E92) Forum
2009 E90 335i M-Tech - Fully Modded
01-09-2013, 12:33 PM | #1 |
CTCC TC 2008 & 2010 Champions
Rep 105
2009 BMW 335i Sedan (E90) 92,000 Kms Saffire Black on Saddle Brown 6spd Manual Current Tires: 225/40/18 Pilot Super Sport 255/35/18 Pilot Super Sport OEM Upgrade Options: M-Tech Package Navigation Package Dakota Saddle Brown Leather Sport Seats Adjustable Lumbar Support USB Audio Integration 3M Clear Bra Wheel Protection Package Aftermarket Upgrades: Eisenmann E90 335i 4x76mm Quad Sport Performance 3d Design CF Quad Rear Diffuser (Dry Carbon) M3 Bushing Conversion (Full Car) M3 Front Strut Tower Brace Kit M3 Front Control Arm/Tension Strut Set M3 Aluminum Rear Guide Rod Set M3 Aluminum Rear Wishbone Set M3 Rear Sway Bar Kit BMW V2 Performance Suspension (With BMW Yellow Springs & Front Sway Bar) Megan Racing Rear Toe Control Arms Stoptech Stainless Steel Brake Lines Engine Software (Choice of GIAC Stage 2 with flash loader or Dinan Stage 2) Cp-e Catted Downpipes OS Giken TCD Superlock LSD VAC Race Aluminum Finned Diff Cover Dinan High Capacity Oil Cooler Dinan Carbon Fiber Cold Air Intake aFe Silver Bullet Throttle Body Spacer Helix Stepped Intercooler BMS Short Throw Clutch Stop BMS Oil Catch Can BMS Modified Clutch Valve UUC DDSR Shifter Kit HPA Adjustable Sway Bar End Links HPA Z4 Tie Rod Assembly Macht Schnell Competition Wheel Spacer Kit 10mm (Front) Macht Schnell Competition Wheel Spacer Kit 12mm (Rear) Velocity Motorcars Wheel Bolts Black Finish Macht Schnell E9X 3-Series Intake Charge Scoops Uninstalled items: STETT Performance 135i/335i Charge Pipe BMW E90 3 Series M3 Style Carbon Fiber Trunk Spoiler BMW E90 LCI 3 Series M Tech Carbon Fiber Front Splitters Angel Eyes Upgrade LED BMW OEM M3 Rear Lower Camber Link Conversion Kit Rotora BBK Front & Rear -FC6 Front Caliper (6 Piston) -FC4 Rear Caliper (4 Piston) -Front Brake 355 x 32 -Rear Brake 355 x 32 Both Turbos and Wastegates replaced by BMW at 70,000 Km under warranty. New Front Rotors and Pads at 86,000 km New Rear Rotors and Pads at 90,000 km Carbon Walnut Blasting to Intake Manifold completed at 60,000 Km by Budds BMW The car has been fully serviced by BMW Autohaus. Vehicle has Extended maintenance package up to 96,000 Km which includes all consumables (clutch, brake rotors, pads, wipers, etc). There are plenty of upgrades, however the car drives beautifully and feels OEM. This is a true M3 killer, on and off the track. Also comes with a set of 17" BMW winter rims with TPMS and Toyo OBSERVE GARIT KX 215/50/17 all around with 70% left (an absolute amazing winter tire). $39,000 OBO Pictures to follow shortly. Last edited by arapone; 01-09-2013 at 01:13 PM.. |
01-16-2013, 03:16 PM | #4 |
Rep 105
I've been having some camera issues the past little while. These were taken with a borrowed Nikon.
I took these pictures with the winter setup. I will try to take some better ones later with the summer setup. 2009 BMW 335i (E90) - Winter Setup |
05-13-2013, 09:34 AM | #7 |
Rep 105
It is an amazing LSD and highly recommend it to anyone looking.
The car is pending final sale, so no parting. |
