BMW 3-Series (E90 E92) Forum
Why does the nav take me the long way?
08-26-2007, 01:10 PM | #1 |
Leave the gun. Take the Canoli.
9055
Rep 7,621
I have my nav set to "frastest" route. In many cases it will route me in a way that I know is longer. You could argue that it doesn't know the shorter way, but if I start driving in that direction then it will appropriately route me that way. Just the other day it told me it was going to take me 20 min to get somewhere. I started driving the shorter way and after it corrected its route to that way the ETA was cut in half down to 10min. So obviously it knows the route exists and is faster, but doesn't take me that way
Why does it do this? Anyone else have this experience?
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40
Retired: 2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe |
08-26-2007, 01:29 PM | #2 |
Rep 798
It does all sorts of crazy things, some of which can be explained by inadequate info for RTTI.
I find main problem is during rush hour traffic on freeway, when it doesn't assume any issue with side streets. However, it still has relatively-correct speed info for highway traffic that I can see by the black arrows. It will routinely re-route me in slow traffic to side streets, that has 4 times the distance. Seems that Navi would need to estimate that I need to go > 80mph (average) on side street to break even. This nonsensical result tells me that the computer may assume that if slow traffic occurs it may think that it will worsen to dead stop, so that its algorithm recommends reroute. Period. That's my guess. The re-routing info also seems to be highly sporadic and "indecisive", as if it is simply displaying the results of possible alternative routes before "concluding" the best path. Most of the time it is good for indicating slow traffic from traffic accident, but some times, no response. Lot of hit and miss with RTTI at the moment that is sure to improve next generation. |
08-26-2007, 01:31 PM | #3 |
9055
Rep 7,621
I'll go with you on all that except for that there is no RTTI in my city yet. So that shouldn't be causing it any confusion.
as an aside, I'm thinking that RTTI is still sort of in its infancy as a technology, but that a few years down the road will be much nicer.
08-26-2007, 01:57 PM | #4 |
Rep 96
It gets worse...not only will it take you the long way, down unnecessary side-streets, but I found that it often didn't notify me to make a turn until I had passed through the intersection! The Nav system is pretty frustrating...my Blackberry gives better navigation and directions truthfully...
08-26-2007, 03:04 PM | #5 |
BK Employee of the month! / Moderator
638
Rep 15,795
I noticed that if you used fastest route, it will sometimes be longer in distance, because it chooses highways, freeways etc... to get you there faster. If you choose the shortest route, then it will choose the shortest distance, but it will mostly use local roads where there are traffic lights, which might get you there in a longer period of time.
That's what I've noticed. Hope this helps! Btw, I love the Nav. I have no problems yet. (knock on wood)
Sponsored by: Pics of the ---> Barbera Beast <--- Martino Auto Concepts (Like them on Facebook MAC) Factory Trained & Authorized by BMW of North America Matt@Camber-Toe (Like them on Facebook Camber-Toe) LuxAngelEyes (Like them on Facebook LuxAngelEyes) LTBMW (Like them on Facebook LTBMW) OEMconcepts (Like them on Facebook OEMconcepts) |
08-27-2007, 02:23 AM | #6 |
9055
Rep 7,621
again, I agree, but it calculated the first route at 20min and when I started heading in the direction I knew was shorter, it revised its thoughts and came up with the new route that was only 10min. Shouldn't it be able to make these comparisons "in its head" before it shows me the fastest route its picked?
