BMW 3-Series (E90 E92) Forum
Hid Relay
09-18-2013, 05:04 PM | #1 |
@McAuley7
11
Rep 419
Hid Relay
Ok I put a relay in for my headlights and it made it worse while engine on, off works perfect.
Relay bad? With no relay hid work ok but if sitting they will flicker and long enough they'll go off. Little help? |
09-18-2013, 05:49 PM | #2 |
uber driver
114
Rep 657
I don't understand. The relay shouldn't work at all when the engine is off because the headlights don't work when the engine is off (unless you hit the blinker switch).
I'm running a relay and everything is working fine. Make sure you grounded it and what not. You should just go through your installation again and make sure everything was done correctly. |
09-18-2013, 05:51 PM | #3 |
Rep 10,120
Bro hit me up I got a set of ballasts that I never installed on my old e90. They are brand new and never used with error cancelors built in. You won't need to worry about that realy crap with this setup
09-18-2013, 06:53 PM | #4 | |
@McAuley7
11
Rep 419
09-19-2013, 03:43 AM | #6 |
Rep 322
Is your relay connected to your battery 12volt terminal?
Add Ons: Charcoal Filter Delete, K&N Drop-in, Air Scoops, HID Angel Eyes, Splitters, M3 Lip Spoiler, Gloss Black Kidney Grills, Blackvue DR500-GW, M-Tech rear, BMW Performance Exhaust, M3 control arms, Bilstein HD
