BMW 3-Series (E90 E92) Forum
Gathering my CCC to CIC parts...
06-11-2014, 11:30 AM | #1 |
Rep 1,068
So, after 3 weeks of owning my 06 325xi wagon, I'm doing the CIC retro. Currently the car is CCC with voice control, no usb, no bluetooth, no telephone.
I just picked up a CIC unit, and waiting for news on a CID. But, I need the proper cables, and that green connector (unless there's a plug in adaptor I can use to avoid re-pinning connctors?) I'm keeping my CCC idrive controller (for now). I've read and read, but can't seem to find a source for the necessary cables. CID to CIC CIC to USB ARM REST CIC to USB GLOVEBOX CID display connector (that green one?) thanks! |
06-11-2014, 09:49 PM | #2 |
Rep 1,068
Nevermind. Ordered it all via ECS tuning (300$ for the needed cables, usb etc..)
Any recommendations on CIC emulators? The ebay ones at all good? |
06-17-2014, 01:02 PM | #4 |
Rep 2,203
Hey, would you mind sharing the p/n for cables you bought?
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
06-17-2014, 08:39 PM | #5 |
Rep 1,068
Go to ECS tuning's website.
This is my shopping cart.. USB Adapter Wiring Cable Used when instaling a usb port ES#: 2702820 Mfg#: 61129255716 1 $48.93 $48.93 Adapter Cable Used in CIC system ES#: 245081 Mfg#: 61119185171 1 $36.99 $36.99 Socket Housing - Pack Of 10 8 pole ES#: 2607887 Mfg#: 61136954526KT 1 $26.70 $26.70 Universal Pin Terminal Uncoded - Priced Each 4 Pol type. Used in multiple electrical connections. ES#: 2675906 Mfg#: 61138380696 1 $2.05 $2.05 Radio Trim Trim that surrounds the radio ES#: 119249 Mfg#: 51459118703 1 $22.69 $22.69 USB / Auxiliary Input Socket Provides audio connection to external devices via auxiliary port - Socket only ES#: 2194689 Mfg#: 84109237653 1 $39.26 $39.26 USB Extension Cable 2330mm (7.6 feet) extension cable from BMW ES#: 161483 Mfg#: 61119129360 1 $40.57 $40.57 |
06-17-2014, 08:40 PM | #6 |
Rep 1,068
I will have the socket housings qty 9 for sale, the display CIC connector that you'll need for a CCC to CIC.. don't buy one ! I'll gladly sell you one for a few bucks.. they are a minimum buy of 10 units for 26$..
06-18-2014, 11:53 AM | #7 |
Rep 2,203
I'll gladly take a few off your hands brother!
06-20-2014, 05:44 PM | #10 |
Rep 1,068
Does anyone know if I should get bmw to update all my software before doing my retrofit? Seems if I install a oem alarm.. looks like bmw needs to code and update the car. I have a feeling they cant if I've changed to a cic?
06-21-2014, 08:41 AM | #11 |
Rep 2,203
You could code the alarm yourself man... far as I know I doubt you'd get much from the update.
06-21-2014, 07:47 PM | #12 |
Rep 1,068
I believe it's the dealer coding which is different than the OBD2 port? I'll need a coding expert to chime me in here =)
So far I've gotten all the code, programs, wiring for my items to arrive in the mail. My test coding will be to make my AE's daytime driving lights! =) |
