FORUMS
- 5
| 04-14-2008, 07:03 AM | #1 | |
Special Agent
F01 7-series to get 8 speed automatic transmission.
![]() Quote:
BMW explored other options but the 8 speed was the most efficient. http://www.bimmerfile.com/2008/04/14...eed-automatic/ Last edited by mapezzul; 04-14-2008 at 04:45 PM. |
| 04-14-2008, 02:29 PM | #2 |
Cpt. Buzzkill
8 speeds is definitely one too many. Six speeds are fine, and I guess a seventh gear could be used for cruising, but eight is just overkill.
_.[In a love/hate relationship with...] E92 335i: Space Grey|Coral Red|Aluminum Trim
![]() _________VMR V710s|M-Sport Rear Bumper & Rockers|M3 Spoiler|Golf-T__________Moved on to the misc. Later, brahs. |
| 04-14-2008, 02:42 PM | #4 |
Special Agent
It is an auto and is going to be extremely smooth shifting. The 7 is not a performance model but a luxury car. The idea is to keep gas consumption down and ride quality up the transition between ratios will be smoother. I guess people just do not get it.
| 04-14-2008, 03:11 PM | #5 |
What 7 series driver is really that intenresnted in shifting? You can't even shift in the current 7 unless you use the button paddles on the steering wheel which are a major hassle to use anyway...
The shorter wheel base 7 will get the X5 shifter (as the spy pics show) and I'm assuming the 6-gear trans, that will shift fine. But the longer wheel base 7 with the 8 speed isn't meant for sporty drivers. As many reports indicate BMW is really going to differentiate the short wheel base and long wheel base 7--mostly through interior design and execution. One will be the sport 7, and the other the luxury 7.
E92 335i|Jet Black|Black Dakota|Alu|Step/paddles|ZPP|ZSP|6FL|Navi|Heated Seats|CA
| 04-14-2008, 03:48 PM | #6 |
Cpt. Buzzkill
I still think 8 is overkill. Unless it can solve the endless shifting for the proper gear problem (like in the Lexus LS), I would expect 7 to be just enough. Even if you're not shifting, the computer still has to sort out which gear to be in.
| 04-14-2008, 04:28 PM | #7 |
100% PAID FOR!
lol, here is an easy fix, don't buy an F01...
Problem Solved! Wouldn't bother me though, uh, if I could afford one; however, if there were a manual option, it would be the first pick...
![]() -- '03 330i ZHP -- Marcus |
| 04-14-2008, 04:58 PM | #8 |
![]() Drives: 2008 e92 M3, 2010 e91 328i Join Date: Jul 2007
Hmmm, imagine trying to rebuild the transmission.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
| 04-14-2008, 05:24 PM | #9 |
![]() ![]() ![]() Drives: slower than Ayrton Senna Join Date: Dec 2006
Location: Nürburgring, be there once, your heart, your soul will stay there.
manufactures need to stop putting more gears than needed on new cars
![]() R.I.P. Steve Noh |
| 04-14-2008, 08:41 PM | #10 |
![]() Drives: 2006 BMW M5 Sedan SMG III Join Date: Aug 2007
People do not get it. In a perfect world, a transmission would have an infinite number of gears. The problem with this is the finite time it takes to shift between gears and the finite room in the housing that each gear takes up. As technology progresses more gears have become standard. CVT are trying to achieve infinite gear ratios but they are only currently available for low torque/rpm applications.
I remember when people were claiming that 6 speed manuals were overkill and 5 speed manuals were just fine. They were not, actually. My '86 Scirocco GTX 16V cruised at 4,000/min at 80 mi/hr in fifth. It could have used six or seven gears back then. You have lots of gears to optimize acceleration and a couple of overdrive gears for minimal fuel consumption in the 60-100 mi/hr cruising range. Sportiness is not necessarily lost with eight gears. The M5 has 7 in the SMG III now, it's very sporty, and could probably use an eighth gear. They could crowd the first seven together to enhance accelerations all the way to Vmax (not just for 0-60 mi/hr) while putting an eight gear in to replace the existing top gear for cruising. I think ideally a car should redline in top gear right at the speed where it gets drag-limited (Vmax).
2006 BMW M5 Sedan
SMG III Silverstone Metallic/Black Perforated Merino/Aluminum, X2/4MA/610/322/453/655/416/465/261/496 |
| 04-14-2008, 09:54 PM | #13 |
missing two turbos.
Drives: fast around corners. Join Date: Sep 2005
For those saying 8speed is overkill...
Im sure those smartass BMW engineers know way more than you do. it did say "they explored other options, but 8spd was most efficient".
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty ![]() : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
| 04-14-2008, 10:32 PM | #14 |
Cpt. Buzzkill
Wow, I never doubted the "smartass" BMW engineers. I'm just sayin that the Lexus LS has troubles with the amount of gears it has, and that it's continuously sorting through them.
I'm not saying that that will dictate the future of this transmission.
| 04-14-2008, 10:55 PM | #15 | |
missing two turbos.
Im sure BMW is aware of such problem. lets see how they work it out.
| 04-14-2008, 10:56 PM | #16 |
Cpt. Buzzkill
The LS actually uses an 8spd.^
| 04-14-2008, 11:07 PM | #18 |
Smiling politely
I feel like 8 gears is too many, too. Although, I read a review of the DCT M3 that mentioned the author was cruising in 7th gear at 65 mph and was at... I don't know, maybe 3.5K RPM? Whatever it was, it seemed awfully high in the RPMs, even for an 8400 RPM car. Maybe an 8th gear would be worthwhile for saving gas on long highway trips.
![]() 330i | Black Sapphire | Beige + Burl | Sport | Premium | Cold | Nav | CA | Sat prep |
| 04-14-2008, 11:08 PM | #19 |
missing two turbos.
thank you for correcting. I went back into my bathroom where all my magazines are to confirm.
| 04-14-2008, 11:18 PM | #20 |
Cpt. Buzzkill
LOL^
| 04-14-2008, 11:42 PM | #21 | |
Special Agent
BMW specifically did not want this issue to occur and that is why they have not had more than a 6 auto until well... this is released. The new design is more efficient and the shifting will be smoother and decisive, they would have it no other way. The gearing will be specific to the car, as well as the programs. |
| Bookmarks |
| Thread Tools | Search this Thread |
