12-22-2019, 11:29 PM | #1 |
Rep 72
Led/Low Beams comfort exit
Hi guys,
I can't seem to find out how to enable the led/low beam to remain (headlight courtesy delay) on when exiting the vehicle and locking the doors. Previous vehicles I was able to set the option to enable the lowbeams to remain on for example 60 seconds while the doors remained locked and then it automatically turned off after 60 seconds. I'm sure this vehicle will have a similar feature but not sure how to enable it can anyone help out. Thanks in advance. |
12-23-2019, 07:43 AM | #2 | |
Rep 1,487
Blessed Beyond Measure
12-23-2019, 04:14 PM | #3 |
Rep 226
You have to push the left hand stalk forward as if selecting main beam, then they come on and stay on for as long as you have selected in the ‘lights’ menu.
12-23-2019, 05:07 PM | #4 |
Rep 7,590
Ditto above...I've seen it described in the owners manual and in iDrive. Look for Pathway Lighting in the rear index in your owners manual for instructions.
EDIT: Check your owners manual because I believe the instructions have changed slightly for the G chassis BMWs & iDrive 7. Regardless of the time interval you have set...you must manually initiate pathway lighting. It wont come on automatically/everytime you shut off the car like in a Cadillac...you get to select when you need the lights to stay on to illuminate your way. If you're in a well lit parking lot or drive or street...then there's no need for pathway lighting...so BMW gives you the choice to select when you need it by flicking the flasher stalk. From a past thread on this topic...I believe these are the instruction from the F chassis BMWs and Pathway Lighting: And the instruction below are from the G05 X5 owners manual which will probably be similar to the G11/G12 7 series:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-23-2019 at 05:24 PM.. |
12-23-2019, 10:13 PM | #5 |
Rep 72
