      03-25-2020, 06:32 PM   #1
KML4EVER
Turkey
Drives: G30 520İ LCI M SPORT
F01 N54 performance mods ideas
Hi everyone
i ve got 2009 740i and planning to do the remap but other than that what can i do for more performance? Awaiting for ideas tnx
      04-24-2020, 10:07 AM   #2
atorreon
atorreon's Avatar
Drives: BMW 135i
My buddy just hooked up his bimmercode app to my 750 and unfortunately there are no performance upgrades available. There are a handful of settings to edit though. Only change I made was set the car to have the auto off function deactivated at startup.
2015 BMW 750Li
2013 Porsche Panamera
2008 BMW e82 135i
2000 BMW e39 M5
      06-24-2020, 12:31 AM   #3
hossein_au
Australia
Drives: 2011 BMW 740i (F01)
I didn't think Bimmercode could do any performance update!? I know there are other software packages for tuning, but I thought Bimmercode was just as the name implies: (re-)coding bimmers.
      10-05-2020, 02:14 AM   #4
GTZ
GTZ's Avatar
Greece
Drives: F01 740i
Originally Posted by KML4EVER View Post
Hi everyone
Hello from Greece.
Our car uses Continental MSD87.2 DME.
It is not tunable via OBD but you can tune it out of the car.The problem is that the ZF transmission (6HP19Z) has torque limits to its ECU and you can not bypass this.The solution is to put two jb+ boxes,the 1st at the turbo sensor and the second to the manifold sensor.It will work...and you will have aprox 370hp...
https://burgertuning.com/collections...-quick-install
The one you plug to the turbo pressure is to adjust pressure,the second one is to fake the signal to DME and TCU in order to raise torque limits.There are optimal setting that increase engine prermormance.You must avoid to set extreme values to the internal rotary JB+ switch because ignition advance and fueling are also affected.
This is an 100-200km/h video of my tuned car:
