08-12-2023, 12:05 PM | #1 |
Rep 5
Sagging rear on both sides
Hello friends,
I left my car unattended in a garage for ~2 weeks. Took it out today, the rear was sagging on both sides equally (front was fine!). Upon startup, it immediately inflated back up to normal and gave no errors or warnings. My suspension system has been fully replaced - 2 years ago for the front, lasy year for the rear. Compressor and valves on both occasions 😁. As for my experience, the shocks go out with leaks. I checked for oil leaks and found nothing, but the manual does say that the vehicle can lower itself after such a long period. But it never says whether it's the whole car, or just the rear. As far as I understand, this is a sealed system. What would you do in this situation? I'd rather not pay BMW 100€ for a diagnosis unless I suspected the warranty I have on the parts would come into play. Thanks. |
08-12-2023, 03:20 PM | #2 |
Rep 417
If it was two weeks then I wouldn't worry about it for the time being, especially considering that your suspension is pretty fresh.
And yes, it is acceptable for it to lose air at different rates between axles. |
08-12-2023, 05:58 PM | #3 |
Rep 5
Thanks for the reply man. I felt like the owner's manual mentioning this was just some hopium. Would you consider pulling out the compressor fuse and driving around like that to see whether it keeps deflating a bad idea?
08-13-2023, 03:30 AM | #4 | |
Rep 417
It would indeed be a bad idea. During driving, the vehicle's suspension experiences dynamic loads different from just standing there with weight on its wheels. You will immediately end up with chassis control error messages and VDP might shut down air spring regulation altogether due to inaccessible compressor. This could lead to rapid deflating of air bellows. Last edited by Raimo5; 08-13-2023 at 03:44 AM.. |
